VAD
SSchm9
I am evaluating the VAD application.
Where is the OpenVX* Application Tracer Tool that is noted in documentation?
Reference: https://software.intel.com/en-us/cvsdk-vad-devguide-runing-the-openvx-application-tracer-tool-from-vad
Stav_S_Intel
This tool is part of VAD, when you click the button described in the documentation from withing VAD's GUI you should see the GtaphML Creator- Do you get to that part?
Stav
SSchm9
Stav,
Found my issue.. thought I was going crazy, but found the tool... the button icon seems to be missing in my install. Also when I go to launch the tool, it appears I am not seeing all of its functionality. I have installed the latest 2.2 Beta on windows.. See the attached images.
Please advise
SSchm9
In regards to my last comment made in this post - I have installed the latest Windows 2017R3 version and it appears the VAD tool has the same defects.
UI issue - which may be causing the GraphML Creator inoperable. see attached.
On a side note, can someone define/syntax for the field requirement:
  • Application arguments  - The OpenVX* application’s switches
Please Advise.
