6574 Discussions
anyone know how to bypass tensorflow install (based on only using Caffe and install error below)
Thanks in advance NCS experts!
I've successful installed and run all examples on x86-Ubntu 16.04LTS (cool)
--- trying to install nativly on an ARMv8 target with Ubintu 16.04; however, getting ->
___ error ___*
Couldn't find a supported tensorflow version, installing tensorflow v1.3.0
Collecting tensorflow==1.3.0
Could not find a version that satisfies the requirement tensorflow==1.3.0 (from versions: )
No matching distribution found for tensorflow==1.3.0
You are using pip version 8.1.1, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Installation failed. Error on line 303
user@Ubuntu_LS2084A_BB_Mini:~/workspace/ncsdk$
**** end install error ****
anyone know how to skip the TensorFlow install? I only need Caffe.
Thanks!
Mark D.
https://github.com/movidius/ncsdk/blob/master/ncsdk.conf
Edit the ncsdk.conf from
INSTALL_TENSORFLOW=yes
to
INSTALL_TENSORFLOW=no
and do
make install
