Visual Studio 15 2017 could not find any instance of Visual Studio (demo_squeezenet_download_convert_run.bat
AdvanChipA
I'm using Windows 10  and OpenVINO 2019 R3.1 with Processor Intel Core i7-6500U CPU 64-bit Operating System.   When I ran "demo_squeezenet_download_convert_run.bat"  and got the error message
"CMake Error at CMakeLists.txt:7 (project):
 Generator
  could not find any instance of Visual Studio.
-- Configuring incomplete, errors occurred!"
I also attached demo_squeezenet_download_convert_run status file, CMakeOutput.log, About Visual Studio 15 2017 screenshot and the set path file.
Please advise.  Thanks.
Luis_at_Intel
Hi Law, Alice,
Thanks for reaching out. Make sure you have ran the setupvars.bat under "C:\Program Files (x86)\IntelSWTools\openvino\bin" prior to running the demo script.
If the problem persists, based on About VisualStudio.JPG looks like your Visual Studio* may be missing some install components. Make sure you have the Desktop development with C++ and MS Build (as seen in my screenshot) installed. You can do this by running the Visual Studio Installer app, although I did this with MVS 2019 it should be something similar in v2017. Once that has been done, re-run the setupvars.bat and proceed to run the demo.
Let me know if the issue persists, I am hoping this resolves your issue.
Luis
Luis_at_Intel
Hi Law, Alice,
Luis
AdvanChipA
Thanks Luis.
After installed the Desktop development with C++ and MS Build, both demos are working.
