6595 Discussions
What's the easiest way to create clDNN plugin when linking statically?
AGaru
Hi! We're using OpenVINO 2019.R3 (from GitHub sources) and modify it to be static. Dynamic linking is totally insecure, as it allows anyone to replace the .so file and steal the network. However, I need to create clDNN plugin, is there an easy way to do that without using Core class and loading .so?
Thank you!
