Where link list to verify OpenVINO for Device CPU? Have Error when Run the Image Classification Verification Script
Chiu__Hsien_Hsiang
初学者
4,389 次查看
When Run the OpenVINO sample to run Car classification verification script
and
Have Error message
" … Failed to create plugin C:\Program File (x86)\IntelSWTools\openvino\deployment_tools\inference_engin\bin\intel64\MKLDNNPlugin.dll for device CPU
Please check your environment
Cannot load library 'C:Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engin\bin\intel64\Release\MKLDNNPlug.dl':1114 from cwd: C:\Users\...\Documents\Inte\OpenVINO\Inference_engin_samples_build\intel64\Release
Error"
Is this error CPU requirement or the set Environment path error?
The pc to test run Demo script is using
System Processor:
Intel(R) Atom(TM)x5-Z8350 CPU @1.44GHz 1.44 GHz
Windows 10, 64bits.
Is the CPU meet the OpenVINO requirement?
Where link to verify PC CPU for OpenVINO?
or
if Environment path error, where should be fixed to solve the Error?
0 项奖励
9 回复数
SIRIGIRI_V_Intel
4,389 次查看
Hi Hsiang,
This issue might be due to the system path variable. Can you check whether the path of the MKLDNNPlugin.dll is added to the PATH of system variables.
If not added try to add the path and retry to execute the demos.
If the problem is still not resolved, please provide the complete logs to debug the issue.
Ram prasad
0 项奖励
Tiger__Chris
初学者
4,389 次查看
I have the same issue with Intel(R) Atom(TM) CPU E3845. windows 64bit.
[ ERROR ] Failed to create plugin C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll for device CPU
Please, check your environment
Cannot load library 'C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll': 1114 from cwd: C:\Users\123\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\Release
and the dll is in the right position and i also put environment variable in PATH but it does not work.
0 项奖励
SIRIGIRI_V_Intel
4,389 次查看
Please refer the below quote.
Max L. (Intel) wrote:
Hi Adrian.
Have you followed "Set the Environment Variables" step? https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_...
OpenVINO toolkit environment variables are removed when you close the Command Prompt window. As an option, you can permanently set the environment variables manually.
Feel free to ask any other questions.
Ram prasad
0 项奖励
zhang__duoduo
初学者
4,395 次查看
I have  the exactly the same question, have you solved it?
0 项奖励
SIRIGIRI_V_Intel
4,395 次查看
Have you followed the steps mentioned above?
If you are still facing the issue, try to install the OpenVINO from a Docker image.
Hope this helps.
Ram prasad
0 项奖励
Chiu__Hsien_Hsiang
初学者
4,395 次查看
Hi Ram,
Thanks for your messages and provided solutions
1 Environment path solution, and 2nd solution: install the OpenVINO from a Docker image
Summary:
Yes, I have followed the steps mentioned above,
but still has same error when run the demo.
and
have difficult to follow the 2nd solution : install the OpenVINO from a Docker image.
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_docker_windows.html
Could someone please have make guiding very details step by step to follow how to
How create your Dockerfile
How to built Docker Image
for Install Intel@ Distribution of OpenVINO toolkeit for Windows* from Docker Image
I am using Mini PC for this OpenVINO project. Attached my computer system info screen picture for reference.
Thank you,
Here are the completed steps and CMD logs with 5 Screen pictures  for debug reference.
Attached 5 screen pictures
Picture 1: SetVars ( Re Do Set Environment command)
Picture 2: Add path for MKLDNNPlugin (Manual Add the path of MKLDNNPlugin.dll)
Picture 3: Demo run error Screen (After Run Demo)
Picture 4: Verify MKLDNNPlugin.dll is in the
The MKLDNNPlugin.dll is in the
Picture 5:  MKLDNNPlugin.dll missing
No KLDNNPlugin.dll in the C:\Users\share\Documents\Intel|OpenVINO\interface_engine_samples_build\intel64\Release folder,
and there is no MKLDNNPlugin.dll.
Here is completed Steps and Error logs for reference:
Steps 1: Re do the Environment setup again.
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>cd c:\Program Files (x86)\IntelSWTools\openvino\bin\
c:\Program Files (x86)\IntelSWTools\openvino\bin>setupvars.bat
Python 3.7.7
ECHO is off.
PYTHONPATH=c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;c:\Program Files (x86)\IntelSWTools\openvino\python\python3.7;c:\Program Files (x86)\IntelSWTools\openvino\python\python3;c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer;
[setupvars.bat] OpenVINO environment initialized
Step 2: Manual check Environment Path:
Add new path to the directory path of the MKLDNNPlugin.dll to the PATH of system variables.
"C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Releas"
Step 3: Re-Run the Demo Run the Image Classification Verification Script,      (But still has same error)!
c:\Program Files (x86)\IntelSWTools\openvino\bin> cd C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>demo_squeezenet_download_convert_run.bat
target_precision = FP16
Python 3.7.7
ECHO is off.
PYTHONPATH=C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;C:\Program Files (x86)\IntelSWTools\openvino\python\python3.7;C:\Program Files (x86)\IntelSWTools\openvino\python\python3;C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer;c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;c:\Program Files (x86)\IntelSWTools\openvino\python\python3.7;c:\Program Files (x86)\IntelSWTools\openvino\python\python3;c:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer;
INTEL_OPENVINO_DIR is set to C:\Program Files (x86)\IntelSWTools\openvino
Python 3.7.7
ECHO is off.
Requirement already satisfied: pyyaml in c:\users\share\appdata\roaming\python\python37\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 1)) (5.3)
Requirement already satisfied: requests in c:\users\share\appdata\roaming\python\python37\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.18.4)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\share\appdata\roaming\python\python37\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (1.22)
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\share\appdata\roaming\python\python37\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.6)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\share\appdata\roaming\python\python37\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2019.11.28)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\share\appdata\roaming\python\python37\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (3.0.4)
Download public squeezenet1.1 model
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name "squeezenet1.1" --output_dir "C:\Users\share\Documents\Intel\OpenVINO\openvino_models\models" --cache_dir "C:\Users\share\Documents\Intel\OpenVINO\openvino_models\cache"
################|| Downloading models ||################
========== Retrieving C:\Users\share\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt from the cache
========== Retrieving C:\Users\share\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.caffemodel from the cache
################|| Post-processing ||################
========== Replacing text in C:\Users\share\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt
squeezenet1.1 model downloading completed
Waiting for 0 seconds, press a key to continue ...
Target folder C:\Users\share\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\share\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 folder.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
Creating Visual Studio 16 2019 x64 files in C:\Users\share\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version 10.0.18362.0 to target Windows 10.0.17134.
-- The C compiler identification is MSVC 19.24.28319.0
-- The CXX compiler identification is MSVC 19.24.28319.0
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.24.28314/bin/Hostx64/x64/cl.exe - works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found InferenceEngine: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/inference_engine.lib (Required is at least version "2.1")
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/share/Documents/Intel/OpenVINO/inference_engine_samples_build
###############|| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ||###############
"C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\MSBuild.exe" Samples.sln /p:Configuration=Release /t:classification_sample_async /clp:ErrorsOnly /m
Microsoft (R) Build Engine version 16.4.0+e901037fe for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
###############|| Run Inference Engine classification sample ||###############
        1 file(s) copied.
classification_sample_async.exe -i "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\car.png" -m "C:\Users\share\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16\squeezenet1.1.xml" -d CPU
[ INFO ] InferenceEngine:
        API version ............ 2.1
        Build .................. 37988
        Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\car.png
[ INFO ] Creating Inference Engine
Cannot load library 'C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\inference_engine\bin\intel64\Release\MKLDNNPlugin.dll': 1114 from cwd: C:\Users\share\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\Release
Error
Step 4: checking the the MKLDNNPlugin.dll
But
No KLDNNPlugin.dll in the C:\Users\share\Documents\Intel|OpenVINO\interface_engine_samples_build\intel64\Release floder,
For 2nd solution:
Install Intel® Distribution of OpenVINO™ toolkit for Windows* from Docker* Image
***** Need additional guilding details in step by step
" How to To build a Docker image, create a Dockerfile "
that contains defined variables
and
commands required to create an OpenVINO toolkit installation image.
Need step by step guilding for
Thank you,
0 项奖励
SIRIGIRI_V_Intel
4,395 次查看
Can you copy the MKLDNNPlugin.dll from
to
folder.
Then re-run the verification script.
For the 2nd method:
To install the OpenVINO from a Docker image, install the Docker for windows and follow the below steps to build the Docker image for CPU.
Create the Dockerfile using the following example as a template:
FROM mcr.microsoft.com/windows/servercore:ltsc2019
ENV http_proxy $HTTP_PROXY
ENV https_proxy $HTTPS_PROXY
ARG DOWNLOAD_LINK=http://registrationcenter-download.intel.com/akdlm/irc_nas/13231/w_openvino_toolkit_p_2019.0.000.exe
ADD https://www.python.org/ftp/python/3.7.3/python-3.7.3.exe C:/python-3.7.3.exe
RUN C:\python-3.7.3.exe /passive InstallAllUsers=1 TargetDir=c:\Python37
RUN setx PATH "C:\Python37;C:\Python37\Scripts;%PATH%"
RUN python.exe -m pip --proxy=$https_proxy install cmake
ADD $DOWNLOAD_LINK w_openvino_toolkit_p_2019.0.000.exe
RUN start /WAIT w_openvino_toolkit_p_2019.0.000.exe --s --a install --eula=accept --output=c:\openvino_out.txt
CMD cmd.exe
Change the DOWNLOAD_LINK parameter in line 5 to the latest OpenVINO link and modify the commands in line 17 and 19 as per the requirements.
You can get the DOWLOAD_LINK from the Intel® Distribution of OpenVINO™ toolkit download page https://software.seek.intel.com/openvino-toolkit after registration. Right click the Offline Installer button on the download page in your browser and press Copy link address
To build a Docker* image for CPU, run the following command:
docker build . -t <image_name> \
--build-arg HTTP_PROXY=<http://your_proxy_server.com:port> \
--build-arg HTTPS_PROXY=<https://your_proxy_server.com:port>
0 项奖励
Chiu__Hsien_Hsiang
初学者
4,395 次查看
Hi Ram,
Have Copy and Paste the MKLDNNPlugin.dll from directory, is not able to solve error
and also have tested Manual add all related Environment PATH too, still has same error.
Have difficult to follow the 2nd solution: install the OpenVINO from a Docker image
I have download the Docker Desktop for Windows,and Sign in.
Here is the update dockerfile script I have use
ARG DOWNLOAD_LINK=http://registrationcenter-download.intel.com/akdlm/irc_nas/16359/w_openvino_toolkit_p_2020.1.033.exe
ADD $DOWNLOAD_LINK w_openvino_toolkit_p_2020.1.033.exe
RUN start /WAIT w_openvino_toolkit_p_2020.1.033.exe --s --a install --eula=accept --output=c:\openvino_out.txt
CMD cmd.exe
and
Have set my computer Proxy server IP and port : 172.22.0.1:8800
But have difficult to follow how To build a Docker* image for CPU, how to run the following command:
Tested: Docker Run hello-world, unable to pull the hello-world
"C:\Users\share\Desktop\containers>docker run hello-world
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
docker: no matching manifest for windows/amd64 10.0.17134 in the manifest list entries.
See 'docker run --help'."
Doesn't know where begin to fix docker error, and how to build a Docker* image for CPU.
Could someone make video demo for the install the OpenVINO from a Docker image to follow?
0 项奖励
Chiu__Hsien_Hsiang
初学者
4,395 次查看
Hi Ram,
Have verify the Docker installation,
Change Docker setting to switch to Linux containers, and re-test pull Hello-World.
Hello From docker, confirm Docker (Linux containers) is working correctly.
But if switch Docker back to Windows containers setting, then re-test Hello-World will fail.
C:\Users\share\Desktop\containers\mydockerbuilt>docker run hello-world
Anyone know the solution to makes Docker Windows containers setting works?
and how To build a Docker* image for CPU, how to run the following command:
0 项奖励
回复
