I have download openvino_toolkit_runtime_raspbian_p_2021.4.752 on raspberry pi4b. I want to perform yolov3-tiny on raspberry pi4B with NCS2.But when i try it on Ubuntu18 ,some mistakes happend.
The demo i use is ./intel64/Release/object_detection_demo
I get yolov3-tiny.weights in pjreddie/darknet: Convolutional Neural Networks (github.com)
l really need help
thanks
Hi fizzgo,
Have you tried with OpenVINO™ Toolkit Public Pre-Trained Model, yolo-v3-tiny-tf ?
Besides, please also share the Model Optimizer command in converting your yolo-v3 model.
Peh
Second,l tried yolov3-tiny (I got it from pjreddie).I also converted it successfully,but it ran wrongly.I have described it in my first question.
At last,l tried my own yolov3-tiny model(only one class),it detected nothing.The following pictures shows my orders .
Thanks for your help.
First,l have tried yolo-v3-tiny-tf ,but it performed badly.
I got two files yolo-v3-tiny-tf.json and yolo-v3-tiny-tf by the order : python3 downloader.py --name yolo-v3-tiny-tf
then i used mo_tf.py to convert it to IR(xml bin) successfully.But when i tried it with NCS2,it act like below:
Hi fizzgo,
For the OpenVINO™ Toolkit Public Pre-Trained Model, yolo-v3-tiny-tf, you are getting poor inferencing performance due to the model conversion.
You can use the converter.py script to convert the model or manually use mo_tf.py script to convert with full Model Optimizer arguments:
python3 mo_tf.py --input_shape=[1,416,416,3] --input=image_input --scale_values=image_input[255] --reverse_input_channels --transformations_config=$dl_dir/yolo-v3-tiny-tf/yolo-v3-tiny-tf.json --input_model=$dl_dir/yolo-v3-tiny-tf/yolo-v3-tiny-tf.pb
Next, convert the yolo-v3-tiny model ( get from Pjreddie) with the same Model Optimizer arguments especially the --reverse_input_channels argument.
Lastly, for the custom yolo-v3-tiny model (one class), convert the model with the same Model Optimizer arguments and make sure you have modified the classes in yolo_v3_tiny.json.
Peh
Dear Peh,
Thanks for your help,i have solved my problems.
fizzgo
Hi fizzgo,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
