I trained a model from the pretained model ssd_resnet_50_fpn_coco with tensorflow=1.12.0 . the command i run is
python3 /opt/intel/openvino_2019.1.133/deployment_tools/model_optimizer/mo.py \
--framework=tf \
--input_model /root/sk_person_3.pb \
--tensorflow_use_custom_operations_config /opt/intel/openvino_2019.1.133/deployment_tools/model_optimizer/extensions/front/tf/ssd_v2_support.json \
--tensorflow_object_detection_api_pipeline_config /root/tf_frozen_models/ssd_resnet50/pipeline.config \
--data_type FP32 \
--reverse_input_channels \
--input=image_tensor \
--input_shape=[1,640,640,3] \
--output=detection_classes,detection_scores,detection_boxes,num_detections \
--log_level=DEBUG
but it failed.
I have attached the pb model and debug log to post. Looking forward to your help.
additional,the error happed after i change the ssd_v2_support.json according to this post becase i have the same error.
I try it with openvino_2019.1.144 . it has the same error.
Hi dudu,
We are working out internally to look upon this issue. Reply to you once we get an answer.
Was there any resolution on this? I am encountering the same issue which I have posted about here https://software.intel.com/en-us/forums/computer-vision/topic/820894
Hi John,
Please, use the following command line to convert the model in Intel® Distribution of OpenVINO™ Toolkit 2019 R3:
./mo.py --input_model ./sk_person_3.pb --tensorflow_use ./ssd_support_custom.json --tensorflow_obje ./ssd_resnet_50_v1_fpn_coco.config
The customized ssd_support_custom.json file is attached.
