123-detectron2-to-openvino could run in cpu mode well, but in gpu mode gave err as belove
Dropdown(description='Device:', index=1, options=('CPU', 'GPU', 'AUTO'), value='GPU')
Abort was called at 15 line in file:
cpu:corei7 1165G7 2.8GHz, gpu:Iris Xe Graphics
I set driver and can recongnize gpu correctly.
Does openvino support detectron2 in gpu mode?
could you share:
- Which model are you using?
- Relevant model files
- which inferencing code did you use to infer this?
- commands that you used till the point of error
Cordially,
Iffa
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
