edge device hardware
bartlino
Im making a Yolo7 app with this:
Can someone recommend me a linux hardware to run on in an edge device application?
Is the NN Compute stick 2 still supported? Would there be directions on how to set this up on a new rasp pi 4 to run Yolov7 from the repo I linked?
Any edge device hardware recommendations please send my way....thank you. Does open VINO support this CPU & GPU?
Ben
Aznie_Intel
Hi Ben,
Thanks for reaching out.
Neural Compute Stick 2 (NCS 2) is supported in OpenVINO™ 2022.1 package. You may check the OpenVINO Installation page.
On another hand, Intel® Distribution of OpenVINO™ toolkit is not supported on AMD Ryzen CPU. Only Intel® hardware is officially supported for OpenVINO™ toolkit. I would recommend you to check our System Requirements to decide the best hardware for your application.
As for the setup for Raspberry Pi with OpenVINO™ and NCS 2, follow the Install OpenVINO™ Runtime for Raspbian OS guide and ensure step 5 is successfully implemented.
Aznie
Aznie_Intel
Hi Ben,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
