6575 Discussions
executable network (blob) for NCS2 significantly larger than source (xml+bin)
sonebu
I'm using the Python API, OpenVINO 2020.4 and primarily do development on the NCS2 (-d MYRIAD)
I read a network in from the xml + bin source using functions read_network() and load_network(). Then I export the executable network as a blob file. The xml + bin file is of size A bytes, and the blob is of size B bytes.
I've consistently seen B>A by a significant margin of ~2-3 MB for all models that I've tested from the open model zoo. Is this expected behavior? Is there any way to avoid it?
IntelSupport
Community Manager
Hi Sonebu,
Thanks for reaching out.
Probably no, the size of the blob file should be the same as the XML + bin file.
You can check this page on how to run the MYRIAD compile to get the blob file. Then, you will see the blob file and the XML + bin file should be in the same size.
https://docs.luxonis.com/tutorials/converting_openvino_model/#run-myriad_compile
Aznie
IntelSupport
Community Manager
Hi Sonebu,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
