face detection with face-detection-adas-0001 in opencv
naserpiltan
초급자
3,116 조회수
Hello everybody
I am developing a face detection APP with opencv in c++,i wanna use the ace-detection-adas-0001 model in my app.
System information :
OS : ubuntu 18.04
framework :Qt
compiler :GCC
openvino : l_openvino_toolkit_p_2020.2.120
opencv : openvino pre-built opencv 4.3.0
This is my tets code :
Net net = readNet("face-detection-adas-0001.bin","face-detection-adas-0001.xml");
Mat image = imread("image.jpg");
Mat blob = blobFromImage(image,1.0,cv::Size(672, 384),0);
net.setInput(blob);
Mat res = net.forward();
Mat objectMask(res.size[2], res.size[3],CV_32F, res.ptr<float>(0,1));
objectMask = objectMask.reshape(1, objectMask.total() / 7);
for(int i = 0 ; i < objectMask.rows ; i++)
float score = objectMask.at<float>(i, 2);
cout<<objectMask.at<float>(i, 0)<<endl;
if(score > 0.5)
int classId = static_cast<int>(objectMask.at<float>(i, 1));
//cout<<classId<<endl;
int left = static_cast<int>(image.cols * objectMask.at<float>(i, 3));
int top = static_cast<int>(image.rows * objectMask.at<float>(i, 4));
int right = static_cast<int>(image.cols * objectMask.at<float>(i, 5));
int bottom = static_cast<int>(image.rows * objectMask.at<float>(i, 6));
left = max(0, min(left, image.cols - 1));
top = max(0, min(top, image.rows - 1));
right = max(0, min(right, image.cols - 1));
bottom = max(0, min(bottom, image.rows - 1));
Rect box = Rect(left, top, right - left + 1, bottom - top + 1);
rectangle(image, Point(left, top), Point(right,bottom), Scalar(255, 0, 0));
imshow("sss",image);
waitKey(0);
I can build and run my test code successfully in Qt.
But it gives me very bad results and can not detect any face properly.
Can the problem be the openvino or opencv ?
I have not any idea about the problem.
Any help would be greatly appreciated
Thanks in advance.
0 포인트
1 솔루션
SIRIGIRI_V_Intel
3,116 조회수
Mat objectMask(res.size[2], res.size[3],CV_32F, res.ptr<float>());
The pointer to the result should be provided as the parameter to the objectMask. For more details, Please refer this Documentation.
Ram prasad
원본 게시물의 솔루션 보기
0 포인트
4 응답
SIRIGIRI_V_Intel
3,116 조회수
Hi Naserpiltan,
Could you please try to replace the below line
to
Hope this helps
Ram prasad
0 포인트
naserpiltan
초급자
3,116 조회수
Hello Ram prasad
Thank you so so much.Yeah now i can detect face very nice and it works like a charm with your solution.
But can you describe what was my prblem ?
i was picking the 0 and 1 dimentions of ouput tenosr in my test code. but what about now ?we are picking all dimentions ?why?
Thank you
0 포인트
SIRIGIRI_V_Intel
3,117 조회수
Ram prasad
0 포인트
naserpiltan
초급자
3,116 조회수
@Ram prasad i got it .
Thank you so much.
0 포인트
응답
