image translation model
gb8
When using  'omz_converter',
   segmentation_model, hrnet-v2-c1-segmentation.xml created.
But 'translation_model, cocosnet.xml doesn't.
Document says,
  -m_trn TRANSLATION_MODEL : required
  -m_seg SEGMENTATION_MODEL : optional
And running the demo without translation model produces error as follows,
  error message : ipykernel_launcher.py: error: the following arguments are required: -m_trn/--translation_model, -o/--output_dir
gb8
Peh_Intel
Hi gb8,
There are two ways to run with this demo. You can refer to commands here.
Besides, there are also some fixes to the preprocessing for Segmentation and Translation models.
Please modify these two files (models.py and preprocessing.py) in the
<omz>/demos/image_translation_demo/python/image_translation_demo directory.
Here are the changes that required to be made.
Peh
Vladimir_Dudnik
@gb8 what was the issue of using omz_converter ?
Note, when you want to load models for particular demo, it might be convenient to use models.lst file from demo folder as a parameter for omz_downloaded or omz_converter tools.
I've just tried under OpenVINO 2022.1 python environment
omz_downloader --list <omz_dir>/demos/image_translation_demo/python/models.lst -o <out_dir>
omz_converter --list <omz_dir>/demos/image_translation_demo/python/models.lst -o <out_dir> -d <out_dir> --precisions FP16
and models listed in models.lst file were downloaded and converted
Remember, when you install openvino-dev into python environment where you plan to convert the models to IR, you also need specify extra dependencies for frameworks you are going to use (or simple list all supported OpenVINO frameworks)
you can do so by running command like this:
pip install openvino==2022.1 openvino-dev[caffe,onnx,tensorflow2,pytorch,mxnet,paddle,kaldi]==2022.1
This will install OpenVINO runtime and tools and also all required deps of proper versions to make conversion to IR from all these frameworks.
gb8
After model_downloader command, folder structure is as follows,
So, model download seems to be completed normally.
download command  in vscode is :
os.system("omz_downloader --list models.lst -o /home/pi/code/models --cache_dir /home/pi/code/models/cache")
I converted the models as following command in vscode'
  - os.system("omz_converter --list models.lst -d /home/pi/code/models -o /home/pi/code/models")
And segmentation model was converted well as I mentioned earlier.
Suggestion : some kind of downloader, converter command result message ( success, fail and more info.) would be helpful.
gb8
gb8
note)
  above convert command produces '256'.
gb8
I am very sorry.
I overlooked the output message of downloader and converter because it is so long and always did well for other examples.
There is converting error for cocosnet as follows:
gb8
Peh_Intel
Hi gb8,
Below are the results that I convert CocosNet model via Command Prompt. As you see, the result messages (success, fail and info) are shown.
I tried to convert CocosNet model without installing the dependencies and the conversion was failed.
Please make sure you run the command below to install the dependencies:
pip install openvino-dev[pytorch]==2022.1
Peh
gb8
Hi Peh.
Your mention succeed.
Former result : I installed using comand someday before as follows,
  - 'pip install ‘openvino-dev[caffe, kaldi, mxnet, onnx, pytorch, tensorflow2]’
Now using comamnd,  - 'pip install openvino-dev[pytorch]==2022.1'
it succeed.
Is there difference between  the two pip command?
Thanks a lot.
gb8
Peh_Intel
Hi gb8,
Thanks for confirming you are running well now.
Both pip commands are actually the same, the only difference is just to specify the version. Installing OpenVINO™ from PyPI without specifying the version, it will install the latest version at that moment.
Peh
gb8
Peh.
Thank you for detailed explanation.
After installation successful, I ran the demo according to doc, it says only '-ri'(reference images) argument is required, and other images are optional.
Running with that argument, it shows error as follows:
So I rearranged arguments like '-ii imagefile -ri imagefile' (same image file for test), then error message is as follows:
I am not familiar with image translation, I just want to introduce this model to people.
For this demonstration to work, Can I get suitable images ? If possible.
gb8
Peh_Intel
Hi gb8,
Peh
gb8
OK.
I see.
I am not familiar with image translation as mentioned before,
I would rather postpone the test until everything is fixed.
I respect you for hard work if not impossible.
Thanks a lot.
gb8
Peh_Intel
Hi gb8,
I’ve validated the demo works fine on my side after modifying these two files (models.py and preprocessing.py).
Command used:
python image_translation_demo.py -m_trn cocosnet.xml -m_seg hrnet-v2-c1-segmentation.xml -ii horse.jpg -ri zebra.jpg -o output
Besides, I also attached these two modified files as well. You can replace these two files in the directory below:
Peh
gb8
Yes. I tested it and everything is OK.
Thank you.
gb8
Peh_Intel
Hi gb8,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
