#include <ie_core.hpp> no such file or directory
Alves_Tasca__Arthur
I am running an Ubuntu 18.04.3 LTS with OpenVino installed at /opt/intel/openvino_2019.3.334. I am getting started with OpenVino in C++ and I have been running into error while trying compile a file with:
the error retrieved is:
my_ie_test.cpp:3:10: fatal error: inference_engine.hpp: No such file or directory
 #include <inference_engine.hpp>
Moreover, I have successfully completed and tested the installation test described in the installation guide. I have also payed attention to add to ~/.bashrc the line
source /opt/intel/openvino_2019.3.334/bin/sertupvars.sh
And my terminal is being intiallized with the message "[setupvars.sh] OpenVINO environment initialized".
Why can't I import this file and how can I solve this issue?
Cary_P_Intel1
Hi, Arthur,
There are two ways to write your own code then compile with the right environment setting.
1. add your code under the "<OpenVINO_root>/inference_engine/samples" by creating a new folder and put your code into the folder, and copy the CMakeLists.txt file from any of the sample existing to your folder, then change the name within the "ie_add_sample" macro.
For example, if you create your sample as "my_ie_test" so you create a folder under the samples named "my_ie_test" and with your own source code named "my_ie_test.cpp", then you copy the CMakeLists.txt from "hello_query_device" to your folder. What you need to change is as below, then run the "build_samples.sh" again, you will see the binary built.
ie_add_sample(NAME my_ie_test SOURCE "${CMAKE_CURRENT_SOURCE_DIR}/my_ie_test.cpp")
2. Leverage the find_package(InferenceEngine) in CMakeLists.txt file as what I made attached in the zip file, then you can build it from wherever you want.
Marcia_W_Intel
Thanks for the files.
FYI to devs using option #2
in the CMakeLists.txt file...
"test" is reserved, so change this name for your project.
