6574 Discussions
intel_gpu_top shows 100% with nothing running
sg
The following is the output from intel_gpu_top  when nothing is running.  What is wrong and how should that  be  investigated ?  Do not see any option for verbose or debug options.  This is context of using the hw_decode.c sample from FFmpeg using vaapi,  trying to see how of the internal GPU resources are used. Just mentioning, although I do not think  that plays any role with the intel_gpu_top  incorrect output.
                   render busy:   0%:                                        render space: 0/4096
                          task  percent busy
                           FBC: 100%: ████████████████████    vert fetch: 0 (0/sec)
                           SDE: 100%: ████████████████████    prim fetch: 0 (0/sec)
                            CS: 100%: ████████████████████ VS invocations: 0 (0/sec)
                            RS: 100%: ████████████████████ GS invocations: 0 (0/sec)
                           GAM: 100%: ████████████████████      GS prims: 0 (0/sec)
                          GAFM: 100%: ████████████████████ CL invocations: 0 (0/sec)
                           TSG: 100%: ████████████████████      CL prims: 0 (0/sec)
                           VFE: 100%: ████████████████████ PS invocations: 0 (0/sec)
                          GAFS: 100%: ████████████████████ PS depth pass: 0 (0/sec)
                           SVG: 100%: ████████████████████
                          URBM: 100%: ████████████████████
                           TDG: 100%: ████████████████████
                            SF: 100%: ████████████████████
                            CL: 100%: ████████████████████
                           SOL: 100%: ████████████████████
                            GS: 100%: ████████████████████
                            DS: 100%: ████████████████████
                            TE: 100%: ████████████████████
                            HS: 100%: ████████████████████
                            VS: 100%: ████████████████████
                            VF: 100%: ████████████████████
