6583 Discussions
libcpu_extension_avx2.so No such file or directory Error
Na__Taeho
Hi
I have installed OpenVINO for CVAT on Mac, but some problem with 'libcpu_extension_avx2.so'.
  • OS : macOS Catalina 10.15.1
  • OpenVINO : 2020.1.023
When executing the 'Auto Segmentation' function or click 'Submit' button after all necessary files attached in 'Upload a new model' page, the following error occurs.
Cannot load library '/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libcpu_extension_avx2.so': /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libcpu_extension_avx2.so: cannot open shared object file: No such file or directory '
There is no 'libcpu_extension_avx2.so' file in the path '/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/' in my Mac.
How can I get the 'libcpu_extension_avx2.so' file?
I want to solve the error.
Max_L_Intel
Hi Taeho.
Unfortunately, as one of backward incompatible changes compared with OpenVINO toolkit 2019 R3 build, the CPU extensions library libcpu_extension_avx2.so was removed in 2020.1 build, so the extensions were moved into the plugin.
You could try OpenVINO toolkit 2019 R3 build.
Best regards, Max.
Khalitov__Artem
what kind of plugin? How to use it ? Can I elaborate?
Li__Rachel
what kind of plugin? How to use it ? Can I elaborate? + 1
Li__Rachel
Where to get the libcpu_extension_avx2.so. Could you please elaborate?
https://docs.openvinotoolkit.org/latest/ie_python_api/classie__api_1_1IECore.html#adf1cf8c8d741ece2e18fad9dbc14a076
ie = IECore()
ie.add_extension(extension_path="/some_dir/libcpu_extension_avx2.so", device_name="CPU")
Max_L_Intel
Hello, Artem, Rachel.
In OpenVINO toolkit 2020.1 build CPU extensions (including AVX) have been included into CPU MKL-DNN plugin - https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_CPU.html
The plugin file libMKLDNNPlugin.so is located in the same directory: openvino/deployment_tools/inference_engine/lib/intel64/
If you see any errors related to missing libcpu_extension_avx2.so file from any OpenVINO toolkit 2020.1 embedded tools, please let us know.
