Hi
I have installed OpenVINO for CVAT on Mac, but some problem with 'libcpu_extension_avx2.so'.
- OS : macOS Catalina 10.15.1
- OpenVINO : 2020.1.023
When executing the 'Auto Segmentation' function or click 'Submit' button after all necessary files attached in 'Upload a new model' page, the following error occurs.
Cannot load library '/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libcpu_extension_avx2.so': /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libcpu_extension_avx2.so: cannot open shared object file: No such file or directory '
There is no 'libcpu_extension_avx2.so' file in the path '/opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/' in my Mac.
How can I get the 'libcpu_extension_avx2.so' file?
I want to solve the error.
Hi Taeho.
Unfortunately, as one of backward incompatible changes compared with OpenVINO toolkit 2019 R3 build, the CPU extensions library libcpu_extension_avx2.so was removed in 2020.1 build, so the extensions were moved into the plugin.
You could try OpenVINO toolkit 2019 R3 build.
Best regards, Max.
what kind of plugin? How to use it ? Can I elaborate?
what kind of plugin? How to use it ? Can I elaborate? + 1
Where to get the libcpu_extension_avx2.so. Could you please elaborate?
ie = IECore()
ie.add_extension(extension_path="/some_dir/libcpu_extension_avx2.so", device_name="CPU")
Hello, Artem, Rachel.
In OpenVINO toolkit 2020.1 build CPU extensions (including AVX) have been included into CPU MKL-DNN plugin - https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_CPU.html
The plugin file libMKLDNNPlugin.so is located in the same directory: openvino/deployment_tools/inference_engine/lib/intel64/
If you see any errors related to missing libcpu_extension_avx2.so file from any OpenVINO toolkit 2020.1 embedded tools, please let us know.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
