6597 Discussions
libcpu_extension.so alternative for windows
Cuenza__Jonathan
I'm trying to use object_detection_demo_yolov3_async.py  but it is giving me this error "[ ERROR ] Please try to specify cpu extensions library path in sample's command line parameters using -l or --cpu_extension command line argument", The problem is im running it on windows. I hope someone can help me. Thanks and God bless...
Cuenza__Jonathan
Ok nevermind i found the dll C:\Users\<username>\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\Release\cpu_extension.dll
Shubha_R_Intel
Dear Cuenza, Jonathan,
Glad you found it. Yep in Windows it's a *.dll not an *.so, and it's found in the exact location which you discovered. It's built when you build the OpenVino samples.
Shubha
GMath7
Could you please tell me the GPU extension dll to use in Windows(GPU) for OpenVINO application.
regards,
Gina Mathew
Luis_at_Intel
Hi Matthew, Gina,
Thanks for reaching out. This thread has already been answered and is now closed. Please open a new thread with your question and I will be more than happy to assist.
Luis
