I met two problem using clDnnPlugin of openvino:
1. LoadNetwork is too slow; I changle my model with --data_type FP16 ; the last IR model is 90MB; Code as follow:
Core ie;;
network = ie->ReadNetwork("model.xml", "model.bin");
ExecutableNetwork executable_network = ie->LoadNetwork(network, "GPU");
2. I have wrapped inference_engine to my application; the memony is not recovery after call my destructor. do I need to explicitly call destructors of "Core", "CNNNetwork" ...
I use the issue openvino_2020.2.120 in ubuntu 16.04; I have attached my code.
How can i solve these problems, Looking forward to reply!
Hi Hou,
To increase the loading time, you can use cl_cache feature. However for the first time, the load time will be same and then faster. For more information on cl_cache, refer FAQ (OpenCL).
Please answer the below questions with respect to memory recovery issue:
- Do you see this issue while running on CPU as well?
- Have you seen this issue in previous versions of OpenVINO?
- How do you observed that memory is not released?
Ram prasad
Ram prasad (Intel) wrote:Hi Hou,
Ram prasad
Thanks for your attention. sugguestion for the first question, I will try, thanks again.
About memory recovery:
3. I observed memory by executing "top" (MEM) and "free" (available)
1. I use the same code running on CPU, after calling my wrap class destructor (note: my application not exited), the MEM dropped from 4.2% to 1.2%, but GPU from 5.5% to 5.3%. The available mem of "free" is similar . Meanwhile, If I create and release wrap object circularly, the memory increases continuely. the Code in attachment.
2. I do not compare with previous versions of OpenVINO,
Please refer to the object_detection_demo_ssd_async demo and try a similar approach on your application too.
Ram prasad
