ncs don't work
I have successfully converted yolov3.ckpt to yolov3.xml. It's OK until now. But when I tested the model.ckpt on gtx1050 and the model.xml on ncs1, I got totally different outputs! Obviously the model.ckpt works on the gtx1050 and the model.xml on the ncs1 don't work. I wonder the reason and the way to let model.xml output right.
I just run the mo_tf.py to convert the model
my sdk version is 2018.5.455
my tensorflow version is 1.12.0
Hi @bingoli
There could be an error in the pre processing code. Can you provide all your code please? I can try to run on my computer and get back to you with my findings.
Sahira
