numpy is installed. The code is as below. it says numpy is
import numpy
getting error - RESTART: D:/backup/mpath/Intel/innovation2019/ai/openvino/pythonTutorial/xx.py
Traceback (most recent call last):
File "D:/backup/mpath/Intel/innovation2019/ai/openvino/pythonTutorial/xx.py", line 1, in <module>
import numpy
ModuleNotFoundError: No module named 'numpy'
Need help.
Anita
Did you run setupvars.bin under bin ? (or the Linux variant) ? If you did and the problem still happens :
Please uninstall Openvino and re-install, this time allowing Openvino to install Python for you. If OpenVino + Python are installed properly, and you ran the setupvars script so that environment vars are set properly - you will not have this issue.
just do the pip3 install numpy or pip3 install intel-numpy which is faster. at least its what is advertised.
