I have an issue running object_detect_sample with the following command
./object_detection_sample -i /home/user/people.jpg -m <INSTALL_DIR>/deployment_tools/intel_models/person-detection-retail-0001/FP32/person-detection-retail-0001.xml --bbox_name detector/bbox/ave_pred -d CPU
the issue is here, the bbox layer can't be detected.
DataPtr bbox_pred_reshapeInPort = ((ICNNNetwork&)network).getData(FLAGS_bbox_name.c_str());
if (bbox_pred_reshapeInPort == nullptr) {
throw std::logic_error(std::string("Can't find output layer named ") + FLAGS_bbox_name);
Hi Zhiqi,
What version of OpenVINO are you using? I highly recommend that you upgrade to the latest version if you haven't done so. I ran this command:
/opt/intel/computer_vision_sdk/deployment_tools/inference_engine/samples/build/intel64/Release/object_detection_sample -i people.jpeg -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/person-detection-retail-0001/FP32/person-detection-retail-0001.xml --bbox_name detector/bbox/ave_pred
and was able to run the sample successfully and also fyi you don't have to specify the device flag with CPU as that is the default target device.
Kind Regards,
Monique Jones
Hi Zhiqi,
Kind Regards,
Monique Jones
I upgraded to R3, and this issue is gone. Thank you.
