6574 Discussions
openvino YOLO model performance result of b580
sakata_m
Dear Intel Support,
I'm looking for openvino YOLO model performance result of b580.
I got the following results in my configuration.
I hope to check if those results are proper or not.
Could you tell me any idea?
Yolo infer results:
yolo12m batch 1: Throughput 270.03(fps), Latency average 3.53(ms)
yolo12m int8 batch 1: Throughput 292.53(fps), Latency average 3.36(ms)
Yolo11s int8 batch 1: Throughput 750.91(fps), Latency average 1.28(ms)
Yolo11s int8 batch 2: Throughput 960.29(fps), Latency average 1.99(ms)
Yolo11s int8 batch 4: Throughput 1085.11(fps), Latency average 3.48(ms)
my configuration:
MB: ASRock B760M
CPU: intel Core i7-13700 (HT On, Turbo On)
GPU: intel Arc b580 Limited Edition Graphics (12GB)
Memory: 32GB
OS: Ubuntu 24.04.2 LTS
OpenVINO: 2025.1.0.18503
performance check command example:
> benchmark_app -m yolo12m.xml -t 10 -hint latency -d GPU -b 1
Masaaki Sakata
Zulkifli_Intel
Hi sakata_m,
Thank you for reaching out.
We do not have the YOLOv11 and YOLOv12 performances test on the Intel Arc B580 GPU.
On the other hand, there is a test performed by Ultralytics in the link below. Please note that this performance test is not validated by Intel.
https://docs.ultralytics.com/integrations/openvino/#intel-arc-b580
Zul
sakata_m
Dear Zul-san,
Thanks for your performance test information by Ultralytics.
I found the following page, which describes yolo11 performance(Throughput/Latency) of b580.
https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/model-hub.html
Is this result validated by Intel?
And could you tell me which yolo11 model(yolo11n/yolo11s/yolo11m/yolo11l/yolo11x) is used in the result, if possible?
Masaaki Sakata
Zulkifli_Intel
Hi sakata_m,
Yes, this test is validated by Intel. The performance benchmark test uses the YOLOv11n model. You may refer to the yolov11-optimization notebook.
Zul
sakata_m
Dear Zul-san,
Thanks for your prompt update.
My results are close to intel validated test result.
And I understand my configuration is proper to measure B580 performance.
So, I would like to close this ticket.
Thanks for your help.
Masaaki Sakata
Zulkifli_Intel
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
