Dear Intel Support,
I'm looking for openvino YOLO model performance result of b580.
I got the following results in my configuration.
I hope to check if those results are proper or not.
Could you tell me any idea?
Yolo infer results:
yolo12m batch 1: Throughput 270.03(fps), Latency average 3.53(ms)
yolo12m int8 batch 1: Throughput 292.53(fps), Latency average 3.36(ms)
Yolo11s int8 batch 1: Throughput 750.91(fps), Latency average 1.28(ms)
Yolo11s int8 batch 2: Throughput 960.29(fps), Latency average 1.99(ms)
Yolo11s int8 batch 4: Throughput 1085.11(fps), Latency average 3.48(ms)
my configuration:
MB: ASRock B760M
CPU: intel Core i7-13700 (HT On, Turbo On)
GPU: intel Arc b580 Limited Edition Graphics (12GB)
Memory: 32GB
OS: Ubuntu 24.04.2 LTS
OpenVINO: 2025.1.0.18503
performance check command example:
> benchmark_app -m yolo12m.xml -t 10 -hint latency -d GPU -b 1
Masaaki Sakata
Hi sakata_m,
Thank you for reaching out.
We do not have the YOLOv11 and YOLOv12 performances test on the Intel Arc B580 GPU.
On the other hand, there is a test performed by Ultralytics in the link below. Please note that this performance test is not validated by Intel.
https://docs.ultralytics.com/integrations/openvino/#intel-arc-b580
Zul
Dear Zul-san,
Thanks for your performance test information by Ultralytics.
I found the following page, which describes yolo11 performance(Throughput/Latency) of b580.
https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/model-hub.html
Is this result validated by Intel?
And could you tell me which yolo11 model(yolo11n/yolo11s/yolo11m/yolo11l/yolo11x) is used in the result, if possible?
Masaaki Sakata
Hi sakata_m,
Yes, this test is validated by Intel. The performance benchmark test uses the YOLOv11n model. You may refer to the yolov11-optimization notebook.
Zul
Dear Zul-san,
Thanks for your prompt update.
My results are close to intel validated test result.
And I understand my configuration is proper to measure B580 performance.
So, I would like to close this ticket.
Thanks for your help.
Masaaki Sakata
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
