openvino not working
namahake
Installation on Intel Silicon · openvinotoolkit/stable-diffusion-webui Wiki · GitHub
I installed stable diffusion and openvino as follows. Everything is fine but when I run it, in the script dropdown there is no option Accelerate with OpenVINO.
Wan_Intel
Hi namahake,
Could you please follow the steps below and see if the issue can be resolved?
  1. Add huggingface_hub==0.20.2 to requirements_versions.txt
  2. Activate your venv (On windows it's venv\Scripts\activate)
  3. Run pip install -r requirements_versions.txt
  4. Run webui-user.bat
Wan
Wan_Intel
Hi namahake,
This case will no longer be monitored since we have provided solution. If you need additional information from Intel, please submit a new question.
Wan
