6593 Discussions
run demo_security_barrier_camera with webcam
Hamadouche__Mohand
currently I'm trying to run demo_security_barrier_camera on LAPTOP + Movidius V2
it worked for a front image of a vehicle and a video
   the exec command with the otion -i "<path1>" "<path2>" Required. Path to video or image files. Default value is "cam" to work with cameras.
I have a question; how to make it work using the video stream from the webcam or with a usb camera ?
thanks for any help
Sahira_Intel
To use a USB camera with the examples that require a webcam, you have to specify the path to the stream the video. Try using
-i /dev/video0
That should work unless your USB camera is able to stream more than one stream (ex. RGB, depth & infrared) in which case you'd need to use video1 or video2, etc.
Please let me know if you have any further questions!
Sahira
Hamadouche__Mohand
Hello Sahira
Thank you for your valuable help on the use of stream the video :)
now I'm trying to run it on raspberry Pi 3,
I did not find the execution files of the pre-trained models
on the site OpenVINO-Install-RaspberryPI , where I find example wich's just an face detection example using an image and that outputs out_0.bmp
how can I do the vehicle detection on the rasspberry + movidius + cam ?
  and I would know if i can use the file in "computer_vision_sdk / deployment_tools / demo": demo_security_barrier_camera.sh  of linux openvino in the raspberry to do vehicle detection with the raspberry?
