Environment: ubuntu 16.04 (I installed using apt-get)
The following code has segmentation fault only if `TF_NumDims` is used in a dummy function. dummy function is not used anywhere in the code.
The code is seg faulted at line `ExecutableNetwork executable_network = ie.LoadNetwork(network, device_name, openvino_config);`
include <iostream>
#include <inference_engine.hpp>
#include <opencv2/opencv.hpp>
#include <tensorflow/c/c_api.h>
int64_t dummy (TF_Tensor* tensor) {
return TF_NumDims(tensor); // with this line, segmentation fault at LoadNetwork
// return 0; // with this line, there is no segmentationf fault
int main(int argc, char** argv) {
std::cout << "Hello world!\n";
using namespace InferenceEngine;
try {
const std::string device_name = "CPU";
const std::string input_model = "./ml_runtime-test-data/resnet_v1_50.xml";
const std::string input_param = "./ml_runtime-test-data/resnet_v1_50.bin";
Core ie;
CNNNetwork network = ie.ReadNetwork(input_model, input_param);
network.setBatchSize(1);
InputInfo::Ptr input_info = network.getInputsInfo().begin()->second;
std::string input_name = network.getInputsInfo().begin()->first;
input_info->getPreProcess().setResizeAlgorithm(RESIZE_BILINEAR);
input_info->setLayout(Layout::NHWC);
input_info->setPrecision(Precision::U8);
DataPtr output_info = network.getOutputsInfo().begin()->second;
std::string output_name = network.getOutputsInfo().begin()->first;
output_info->setPrecision(Precision::FP32);
const std::map< std::string, std::string > openvino_config;
InferRequest infer_request = executable_network.CreateInferRequest();
std::cout << input_name << std::endl;
std::cout << output_name << std::endl;
cv::Mat mat = cv::imread("./ml_runtime-test-data/golden-retriever-puppy.jpg", cv::IMREAD_COLOR);
size_t channels = mat.channels();
size_t height = mat.size().height;
size_t width = mat.size().width;
size_t strideH = mat.step.buf[0];
size_t strideW = mat.step.buf[1];
InferenceEngine::TensorDesc tDesc(InferenceEngine::Precision::U8,
{1, channels, height, width},
InferenceEngine::Layout::NHWC);
Blob::Ptr imgBlob = InferenceEngine::make_shared_blob<uint8_t>(tDesc, mat.data);
infer_request.SetBlob(input_name, imgBlob); // infer_request accepts input blob of any size
infer_request.Infer();
Blob::Ptr output = infer_request.GetBlob(output_name);
InferenceEngine::TBlob<float32_t>& tblob = dynamic_cast<InferenceEngine::TBlob<float32_t>&>(*output);
InferenceEngine::SizeVector dims = tblob.getTensorDesc().getDims();
size_t input_rank = dims.size();
size_t batchSize = dims[0];
std::vector<unsigned> indexes(tblob.size());
float32_t* data = tblob.data();
std::iota(std::begin(indexes), std::end(indexes), 0);
std::partial_sort(std::begin(indexes), std::begin(indexes) + 5, std::end(indexes),
[&data](unsigned l, unsigned r) {
return data > data;
std::cout << indexes.at(0) << std::endl;
} catch (const std::exception & ex) {
std::cerr << ex.what() << std::endl;
return 0;
Here is back trace.
[Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". Hello world! [New Thread 0x7fffe65a5700 (LWP 13802)] [New Thread 0x7fffe5da4700 (LWP 13803)] Thread 2 "test" received signal SIGSEGV, Segmentation fault. [Switching to Thread 0x7fffe65a5700 (LWP 13802)] 0x00007fffe913e68c in ?? () from /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libMKLDNNPlugin.so (gdb) bt #0 0x00007fffe913e68c in ?? () from /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libMKLDNNPlugin.so #1 0x00007fffef136cf2 in ?? () from /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libinference_engine.so #2 0x00007fffef1362d9 in ?? () from /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libinference_engine.so #3 0x00007fffede97a99 in __pthread_once_slow (once_control=0x8464098, init_routine=0x7ffff7b07750 <__once_proxy>) at pthread_once.c:116 #4 0x00007fffef13730a in ?? () from /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libinference_engine.so #5 0x00007fffef13650e in ?? () from /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libinference_engine.so #6 0x00007ffff7b088e0 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #7 0x00007fffede906ba in start_thread (arg=0x7fffe65a5700) at pthread_create.c:333 #8 0x00007fffedbc641d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:109
I am able to repeat the above steps in a different machine and got the same segmentation fault.
Topic Options
