6605 Discussions
source ../../setvars.sh not working under Windows
Cagri_T_Intel
I have compiled the binary files under Windows and the following command did not work for me through a command prompt under computer_vision_sdk_2018.3.343\deployment_tools\inference_engine\bin\intel64\Release as per the documentation provided.
Any idea on how to resolve this?
Cagri_T_Intel
Is the correct script supposed to be the following for Windows?
<INSTALLATION DIRECTORY>\bin\setupvars.bat
Mark_L_Intel1
Hi Cagri,
Yes, that should be the script to run.
Mark
Cagri_T_Intel
Hi Mark,
Thanks for your response.
I ran that script and tried to run a face detection model using the following command:
interactive_face_detection_sample.exe -m C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\intel_models\face-detection-adas-0001\FP32\face-detection-adas-0001.xml -d "CPU"
However, I am getting an error saying opencv_world343.dll cannot be found. I can see that this dll is actually located under the following folder:
computer_vision_sdk_2018.3.343\opencv\x64\vc14\bin
It seems the interactive_face_detection_sample.exe cannot locate that folder. Any suggestions on how I can sort this out?
Regards...
Cagri_T_Intel
I found what the issue was. The following script needs to be re-run each time a new command window is created.
After re-running the script in the new window, the face detector started working like a charm!
I think I will add the required variables to my path explicitly to avoid having to remember this detail.
Mark_L_Intel1
Hi Charaw,
Glad to know it works. Yes, put the environment variables would be convenient.
Mark
