- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
Requirements:
Python:3.7
MacOS:Big Sur 11.2.1
Openvino:openvino_2021.3.394
Tensorflow:1.14.0
Description:
When I try to create frozen model from my ssd_mobilenet_v1_fpn_shared_coco model(checkpoint, events.out.tfevents.1613600796.emres-air, graph.pbtxt, model.ckpt-90728.meta, model.ckpt-90728.index, and pipeline.config files), I am getting "detection_classes is not in graph" error, although I am using the same output nodes as defined in intel website.
Could someone tell me what I am doing wrong?
Thanks a lot in advance.
My steps:
1.I downloaded following model from intel website(and output nodes are also defined in this website):
https://docs.openvinotoolkit.org/latest/omz_models_model_ssd_mobilenet_v1_coco.html
2.Custom trained it with following command with my own photos:
2.1 Code:
https://github.com/tensorflow/models
(master branch)
2.2 Command:
python3.7 train.py
--logtostderr
--train_dir=/Users/Documents/Temp/tensorflow_last/models/train
--pipeline_config_path=/Users/Documents/Temp/tensorflow_last/models/ssd_mobilenet_v1_fpn_shared_box_predictor_640x640_coco14_sync.config
Note:I can also attach my config file, if it is related
2.3 Output:
INFO:tensorflow:global step 89547: loss = 0.0628 (8.283 sec/step)
I0629 19:34:56.030186 4505345536 learning.py:512] global step 89547: loss = 0.0128 (8.283 sec/step)
INFO:tensorflow:global step 89548: loss = 0.0596 (9.801 sec/step)
I0629 19:35:05.831597 4505345536 learning.py:512] global step 89548: loss = 0.0196 (9.801 sec/step)
3.I tried to convert my files(checkpoint, events.out.tfevents.1613600796.emres-air, graph.pbtxt, model.ckpt-90728.meta, model.ckpt-90728.index, and pipeline.config files) to frozen model as described in following website:
Parameters:--model_dir
/Users/emre/Documents/Temp/tensorflow_last/models/train/
--output_node_names
detection_classes,detection_scores,detection_boxes,num_detections
3.2Output:At Line 51: (output_node_names.split(",")) I am getting following error message:
assert d in name_to_node, "%s is not in graph" % d
AssertionError: detection_classes is not in graph
Note:my expected output nodes are also not printed out in graph.pbtxt file. (please see attachment)
Best Regards
Emre
Link copiato
- « Precedente
- 1
- 2
- Successivo »
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Syamimi,
Is there any progress?
Emre
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Emre Gun,
I'm sorry for the late reply, I'm just back to work today. As for now, the best method is to change the image size according to the model.
And, yes you are correct. You will lose image quality. If you resize your images down to a smaller, and then size back up again, your image will be a lot less clear. When you resize the image back to the original size, you won't get the original image back.
Syamimi
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Emre Gun,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question
Syamimi
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
- « Precedente
- 1
- 2
- Successivo »
