tensorflow reshape not working on Myriad X
I got this error when I tried to run mvNCCheck on a graph with the tf.reshape() op.
Network Input tensors ['inp:0#6']
Network Output tensors ['out:0#11']
Blob generated
USB: Transferring Data…
USB: Myriad Execution Finished
Output is in Channel Minor format
USB: Myriad Connection Closing.
E: [ 0] dispatcherEventReceive:247 dispatcherEventReceive() Read failed -1
E: [ 0] eventReader:254 Failed to receive event, the device may have reset
E: [ 0] checkGraphMonitorResponse:922 XLink error
Traceback (most recent call last):
File "/usr/local/bin/mvNCCheck", line 228, in
quit_code = check_net(args.network, args.image, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args)
File "/usr/local/bin/mvNCCheck", line 202, in check_net
timings, myriad_output = run_myriad(graph_file, args)
File "/usr/local/bin/ncsdk/Controllers/MiscIO.py", line 335, in run_myriad
graph.destroy()
File "/usr/local/lib/python3.6/dist-packages/mvnc/mvncapi.py", line 778, in destroy
raise Exception(Status(status))
Exception: Status.ERROR
Below is simple code to reproduce the error:
import tensorflow as tf
import os
os.environ['CUDA_VISIBLE_DEVICES'] = str(-1)
x = tf.placeholder(tf.float32, [1, 3, 6, 9], name='inp')
x = tf.contrib.layers.conv2d(x, 9, 1)
y = tf.reshape(x, [1, 162], name='out')
saver = tf.train.Saver()
with tf.Session() as sess:
sess.run(tf.global_variables_initializer())
saver.save(sess, ''path/to/save/my_model')
This is how I ran mvNCCheck
mvNCCheck path/to/save/my_model.meta -w path/to/save/my_model -in inp -on out
If I remove tf.reshape(), everything works fine. Any thoughts on why this is happening?
Hi @yatao
Are you using the Intel Neural Compute Stick 2? If so, you will need to use OpenVINO as the Neural Compute SDK only supports the original Intel Neural Compute Stick.
Take a look at the get started guide: https://software.intel.com/en-us/neural-compute-stick/get-started
Jesus
