where exactly do samples get made to?
Lessio__Nadine
After you run build_samples.sh in the samples directory, where....does it make to in a raspberry pi? The documentation here, just says to run build_samples.sh then.....what? It just magically builds them to somewhere? But doesn't tell you where? I'm just at a loss here. Thanks.
http://docs.openvinotoolkit.org/latest/_docs_IE_DG_Samples_Overview.html
Shubha_R_Intel
Don't the built samples end up in your home directory ?
Shubha
季__智坚
You can find it  here,if you are win10
C:\Users\jzj13\Documents\Intel\OpenVINO\inference_engine_samples_build
