yolov3-tiny model --> tensorflow .pb model --> IR, But the detection accuracy has been reduced a lot.
li__heju
hi,
  My steps is :
   1. train yolov3-tiny model,   input size is 416*416;
    2.convert  by   convert_weights_pb.py (https://github.com/mystic123/tensorflow-yolo-v3),
        the command is : python3.5 convert_weights_pb.py --class_names coco.names --data_format NHWC --weights_file yolov3-tiny_246700.weights --tiny ;
    3.convert .pb to IR  by  mo_tf.py :
       the command: sudo python3.5 mo_tf.py --input_model /home/wrt/Download/yolo/OpenVINO-YoloV3/frozen_darknet_yolov3_model.pb --tensorflow_use_custom_operations_config extensions/front/tf/yolo_v3_tiny_changed.json --batch 1
 All the above steps are normal, but  the detection effect is very poor.
I  only test yolov3-tiny model , it's detection effect is very well;
 Do you have any good suggestions or ideas?
my openvino version is   l_openvino_toolkit_p_2018.5.445
Shubha_R_Intel
Dearest heju:
We just released 2019 R1. Can you try with the latest OpenVino release ?
Thanks for using OpenVino !
Shubha
