any chance that you are behind a proxy network? You'll need to ensure that proxy addresses are configured in the system if you are.
https_proxy=<proxy-address>:<proxy-port>
http_proxy=<proxy-address>:<proxy-port>
HTTP_PROXY=<proxy-address>:<proxy-port>
HTTPS_PROXY=<proxy-address>:<proxy-port>
ftp_proxy=<proxy-address>:<proxy-port>
no_proxy=<list of proxies with your machine ip>
NO_PROXY=<list of proxies with your machine ip>
all_proxy=<socks>:<proxy-address>:<port>
Cordially,
Iffa
Hi Cordially :
we don't used Proxy .
we reboot and run it still meet the address hang up problem . could we know what the IP address is own machine address ?
below is the command after install server20.04 photo for you reference .
1
are you able to download/wget or ping 8.8.8.8 (Google DNS server) on that machine? (best to test download using command).
This is to determine whether the installer or your setup has issues.
Cordially,
Iffa
Hi Coridally :
Hi, I am able to ping 8.8.8.8 and wget http://www.google.com .
this solution might help you.
Another option is to try on a different network, check your IP using ifconfig command and try to see whether the new network works.
Cordially,
Iffa
We will further investigate this and get back to you.
Cordially,
Iffa
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
