Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
411 Discussions
Edge Insights for AMR 2021.3 installation error
Youngsik_Y_Intel
When I ran "docker build --tag amr-ubuntu2004-ros2-foxy-sdk:2021.3 --no-cache --file amr_ubuntu2004_ros2_foxy_sdk_env/Dockerfile amr_ubuntu2004_ros2_foxy_sdk_env" to install EI for AMR 2021.3, I got the following error.
So I changed its dependency "software-properties-common=0.98.9.2" to "software-properties-common" in Dockerfile and it proceeded to the next. But now I encountered the below error in the rtabmap_ros building.
It seems some libs/packages are missing for rtabmap_ros. Could you please check?
<Error log> ////////////////////////////////////////////////////////////////////////////
Step 60/119 : WORKDIR ${ROS2_WS}/src
---> Running in 438e06015a8b
Removing intermediate container 438e06015a8b
---> cf6c22961cfd
Step 61/119 : ARG RTAB_MAP_ROS_COMMIT_ID="c0fbb3f1c35f197ff53aed3a49587f9efe0b544d"
---> Running in 4ba862ecde5b
Removing intermediate container 4ba862ecde5b
---> 084ff02a1253
Step 62/119 : RUN git clone --branch ros2 https://github.com/introlab/rtabmap_ros.git rtabmap_ros     && cd rtabmap_ros        && git checkout ${RTAB_MAP_ROS_COMMIT_ID}
---> Running in c45741875569
+ git clone --branch ros2 https://github.com/introlab/rtabmap_ros.git rtabmap_ros
Cloning into 'rtabmap_ros'...
+ cd rtabmap_ros
+ git checkout c0fbb3f1c35f197ff53aed3a49587f9efe0b544d
Note: switching to 'c0fbb3f1c35f197ff53aed3a49587f9efe0b544d'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
  git switch -c <new-branch-name>
Or undo this operation with:
  git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD is now at c0fbb3f1 Merge pull request #632 from easylyou/ros2
Removing intermediate container c45741875569
---> 2c2eb5c21da7
Step 63/119 : WORKDIR ${ROS2_WS}
---> Running in 30110c8a290f
Removing intermediate container 30110c8a290f
---> d08c65c96b4f
Step 64/119 : RUN source ${ROS_INSTALL_DIR}/setup.bash && colcon build             && rm -rf ${ROS2_WS}/build/* ${ROS2_WS}/src/* ${ROS2_WS}/log/*
---> Running in 1336bc1ab68b
+ source /opt/ros/foxy/setup.bash
++ AMENT_SHELL=bash
++++ dirname /opt/ros/foxy/setup.bash
+++ builtin cd /opt/ros/foxy
+++ pwd
++ AMENT_CURRENT_PREFIX=/opt/ros/foxy
++ '[' -n '' ']'
++ . /opt/ros/foxy/setup.sh
+++ : /opt/ros/foxy
+++ : bash
+++ _prefix_setup_IFS='
+++ IFS='
+++ _UNIQUE_PREFIX_PATH=
+++ '[' -z SKIP_PARENT_PREFIX_PATH ']'
+++ ament_append_unique_value _UNIQUE_PREFIX_PATH /opt/ros/foxy
+++ _listname=_UNIQUE_PREFIX_PATH
+++ _value=/opt/ros/foxy
+++ eval '_values=$_UNIQUE_PREFIX_PATH'
++++ _values=
+++ _duplicate=
+++ _ament_append_unique_value_IFS='
+++ IFS=:
+++ '[' bash = zsh ']'
+++ unset _item
+++ '[' -z '' ']'
+++ '[' -z '' ']'
+++ eval '_UNIQUE_PREFIX_PATH="/opt/ros/foxy"'
++++ _UNIQUE_PREFIX_PATH=/opt/ros/foxy
+++ IFS='
+++ unset _ament_append_unique_value_IFS
+++ unset _duplicate
+++ unset _values
+++ unset _value
+++ unset _listname
+++ unset AMENT_CURRENT_PREFIX
+++ _prefix_setup_AMENT_SHELL=bash
+++ IFS=:
+++ for _path in $_UNIQUE_PREFIX_PATH
+++ '[' -n '' ']'
+++ '[' -f /opt/ros/foxy/local_setup.bash ']'
+++ '[' bash = sh ']'
+++ IFS='
+++ . /opt/ros/foxy/local_setup.bash
++++ AMENT_SHELL=bash
++++++ dirname /opt/ros/foxy/local_setup.bash
+++++ builtin cd /opt/ros/foxy
+++++ pwd
++++ AMENT_CURRENT_PREFIX=/opt/ros/foxy
++++ '[' -n '' ']'
++++ . /opt/ros/foxy/local_setup.sh
+++++ _ament_prefix_sh_AMENT_CURRENT_PREFIX=/opt/ros/foxy
+++++ '[' -z /opt/ros/foxy ']'
+++++ : bash
+++++ _ament_python_executable=/usr/bin/python3
+++++ '[' -n '' ']'
+++++ '[' '!' -f /usr/bin/python3 ']'
+++++ _ament_additional_extension=
+++++ '[' bash '!=' sh ']'
+++++ _ament_additional_extension=bash
++++++ /usr/bin/python3 /opt/ros/foxy/_local_setup_util.py sh bash
+++++ _ament_ordered_commands='export AMENT_PREFIX_PATH="/opt/ros/foxy:$AMENT_PREFIX_PATH"
export PATH="/opt/ros/foxy/bin:$PATH"
export PYTHONPATH="/opt/ros/foxy/lib/python3.8/site-packages:$PYTHONPATH"
export LD_LIBRARY_PATH="/opt/ros/foxy/lib:$LD_LIBRARY_PATH"
AMENT_CURRENT_PREFIX="/opt/ros/foxy" _ament_prefix_sh_source_script "/opt/ros/foxy/share/ros2cli/environment/ros2-argcomplete.bash"
AMENT_CURRENT_PREFIX="/opt/ros/foxy" _ament_prefix_sh_source_script "/opt/ros/foxy/share/ros_environment/environment/0.ros_distro_check.sh"
export ROS_DISTRO="foxy"
export ROS_LOCALHOST_ONLY="0"
export ROS_PYTHON_VERSION="3"
export ROS_VERSION="2"
export LD_LIBRARY_PATH="/opt/ros/foxy/lib/x86_64-linux-gnu:$LD_LIBRARY_PATH"
export LD_LIBRARY_PATH="/opt/ros/foxy/opt/rviz_ogre_vendor/lib:$LD_LIBRARY_PATH"
export LD_LIBRARY_PATH="/opt/ros/foxy/opt/yaml_cpp_vendor/lib:$LD_LIBRARY_PATH"
export LD_LIBRARY_PATH="/usr/lib/x86_64-linux-gnu/gazebo-11/plugins:$LD_LIBRARY_PATH"
if [ "$(echo -n $AMENT_PREFIX_PATH | tail -c 1)" = ":" ]; then export AMENT_PREFIX_PATH=${AMENT_PREFIX_PATH%?} ; fi
if [ "$(echo -n $PYTHONPATH | tail -c 1)" = ":" ]; then export PYTHONPATH=${PYTHONPATH%?} ; fi
if [ "$(echo -n $LD_LIBRARY_PATH | tail -c 1)" = ":" ]; then export LD_LIBRARY_PATH=${LD_LIBRARY_PATH%?} ; fi
if [ "$(echo -n $ROS_PYTHON_VERSION | tail -c 1)" = ":" ]; then export ROS_PYTHON_VERSION=${ROS_PYTHON_VERSION%?} ; fi
if [ "$(echo -n $ROS_VERSION | tail -c 1)" = ":" ]; then export ROS_VERSION=${ROS_VERSION%?} ; fi'
+++++ unset _ament_additional_extension
+++++ unset _ament_python_executable
+++++ '[' -n '' ']'
+++++ eval 'export AMENT_PREFIX_PATH="/opt/ros/foxy:$AMENT_PREFIX_PATH"
++++++ export AMENT_PREFIX_PATH=/opt/ros/foxy:
++++++ AMENT_PREFIX_PATH=/opt/ros/foxy:
++++++ export PATH=/opt/ros/foxy/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++++++ PATH=/opt/ros/foxy/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++++++ export PYTHONPATH=/opt/ros/foxy/lib/python3.8/site-packages:
++++++ PYTHONPATH=/opt/ros/foxy/lib/python3.8/site-packages:
++++++ export LD_LIBRARY_PATH=/opt/ros/foxy/lib:
++++++ LD_LIBRARY_PATH=/opt/ros/foxy/lib:
++++++ AMENT_CURRENT_PREFIX=/opt/ros/foxy
++++++ _ament_prefix_sh_source_script /opt/ros/foxy/share/ros2cli/environment/ros2-argcomplete.bash
++++++ '[' -f /opt/ros/foxy/share/ros2cli/environment/ros2-argcomplete.bash ']'
++++++ '[' -n '' ']'
++++++ . /opt/ros/foxy/share/ros2cli/environment/ros2-argcomplete.bash
+++++++ type register-python-argcomplete3
++++++++ register-python-argcomplete3 ros2
+++++++ eval '
_python_argcomplete() {
    local IFS=$'\''\013'\''
    local SUPPRESS_SPACE=0
    if compopt +o nospace 2> /dev/null; then
        SUPPRESS_SPACE=1
    fi
    COMPREPLY=( $(IFS="$IFS" \
                  COMP_LINE="$COMP_LINE" \
                  COMP_POINT="$COMP_POINT" \
                  COMP_TYPE="$COMP_TYPE" \
                  _ARGCOMPLETE_COMP_WORDBREAKS="$COMP_WORDBREAKS" \
                  _ARGCOMPLETE=1 \
                  _ARGCOMPLETE_SUPPRESS_SPACE=$SUPPRESS_SPACE \
                  "$1" 8>&1 9>&2 1>/dev/null 2>/dev/null) )
    if [[ $? != 0 ]]; then
        unset COMPREPLY
    elif [[ $SUPPRESS_SPACE == 1 ]] && [[ "$COMPREPLY" =~ [=/:]$ ]]; then
        compopt -o nospace
    fi
complete -o nospace -o default -F _python_argcomplete "ros2"'
++++++++ complete -o nospace -o default -F _python_argcomplete ros2
++++++ _ament_prefix_sh_source_script /opt/ros/foxy/share/ros_environment/environment/0.ros_distro_check.sh
++++++ '[' -f /opt/ros/foxy/share/ros_environment/environment/0.ros_distro_check.sh ']'
++++++ . /opt/ros/foxy/share/ros_environment/environment/0.ros_distro_check.sh
+++++++ '[' -n foxy -a foxy '!=' foxy ']'
++++++ export ROS_DISTRO=foxy
++++++ ROS_DISTRO=foxy
++++++ export ROS_LOCALHOST_ONLY=0
++++++ ROS_LOCALHOST_ONLY=0
++++++ export ROS_PYTHON_VERSION=3
++++++ ROS_PYTHON_VERSION=3
++++++ export ROS_VERSION=2
++++++ ROS_VERSION=2
++++++ export LD_LIBRARY_PATH=/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ LD_LIBRARY_PATH=/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ export LD_LIBRARY_PATH=/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ LD_LIBRARY_PATH=/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ export LD_LIBRARY_PATH=/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ LD_LIBRARY_PATH=/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu/gazebo-11/plugins:/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
++++++ LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu/gazebo-11/plugins:/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
+++++++ echo -n /opt/ros/foxy:
+++++++ tail -c 1
+++++++ echo -n /opt/ros/foxy/lib/python3.8/site-packages:
+++++++ tail -c 1
+++++++ echo -n /usr/lib/x86_64-linux-gnu/gazebo-11/plugins:/opt/ros/foxy/opt/yaml_cpp_vendor/lib:/opt/ros/foxy/opt/rviz_ogre_vendor/lib:/opt/ros/foxy/lib/x86_64-linux-gnu:/opt/ros/foxy/lib:
+++++++ tail -c 1
+++++++ echo -n 3
+++++++ tail -c 1
++++++ '[' 3 = : ']'
+++++++ echo -n 2
+++++++ tail -c 1
++++++ '[' 2 = : ']'
+++++ unset _ament_ordered_commands
+++++ unset _ament_prefix_sh_source_script
+++++ unset _ament_prefix_sh_AMENT_CURRENT_PREFIX
+++ unset _path
+++ IFS='
+++ unset _prefix_setup_IFS
+++ unset _prefix_setup_AMENT_SHELL
+++ unset _UNIQUE_PREFIX_PATH
+++ unset AMENT_SHELL
+ colcon build
Starting >>> rtabmap_ros
--- stderr: rtabmap_ros
Member name 'global' in the service request 'GetMap' is a reserved keyword in Python and is not supported at the moment. Please use a different name.
Member name 'global' in the service request 'PublishMap' is a reserved keyword in Python and is not supported at the moment. Please use a different name.
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp: In function ‘rtabmap::Landmarks rtabmap_ros::landmarksFromROS(const std::map<int, geometry_msgs::msg::PoseWithCovarianceStamped_<std::allocator<void> > >&, const string&, const string&, const rclcpp::Time&, tf2_ros::Buffer&, double, double, double)’:
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1338:101: warning: ‘rtabmap::Landmark::Landmark(const int&, const rtabmap::Transform&, const cv::Mat&)’ is deprecated: Use constructor with size=0 instead. [-Wdeprecated-declarations]
1338 |    landmarks.insert(std::make_pair(iter->first, rtabmap::Landmark(iter->first, baseToTag, covariance)));
In file included from /usr/local/lib/rtabmap-0.20/../../include/rtabmap-0.20/rtabmap/core/SensorData.h:42,
                 from /usr/local/lib/rtabmap-0.20/../../include/rtabmap-0.20/rtabmap/core/Signature.h:42,
                 from /home/eiforamr/ros2_ws/src/rtabmap_ros/include/rtabmap_ros/MsgConversion.h:46,
                 from /home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:28:
/usr/local/lib/rtabmap-0.20/../../include/rtabmap-0.20/rtabmap/core/Landmark.h:80:8: note: declared here
   80 | inline Landmark::Landmark(const int & id, const Transform & pose, const cv::Mat & covariance) :
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp: In function ‘bool rtabmap_ros::convertScan3dMsg(const PointCloud2&, const string&, const string&, const rclcpp::Time&, rtabmap::LaserScan&, tf2_ros::Buffer&, double, int, float)’:
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1842:156: warning: ‘rtabmap::LaserScan::LaserScan(const rtabmap::LaserScan&, int, float, rtabmap::LaserScan::Format, const rtabmap::Transform&)’ is deprecated: Use version without "format" argument. [-Wdeprecated-declarations]
1842 |    scan = rtabmap::LaserScan(rtabmap::util3d::laserScanFromPointCloud(*pclScan), maxPoints, maxRange, rtabmap::LaserScan::kXYZRGBNormal, scanLocalTransform);
In file included from /usr/local/lib/rtabmap-0.20/../../include/rtabmap-0.20/rtabmap/core/Transform.h:31,
                 from /home/eiforamr/ros2_ws/src/rtabmap_ros/include/rtabmap_ros/MsgConversion.h:44,
/usr/local/lib/rtabmap-0.20/../../include/rtabmap-0.20/rtabmap/core/LaserScan.h:78:21: note: declared here
   78 |  RTABMAP_DEPRECATED(LaserScan(const LaserScan & data,
/usr/local/lib/rtabmap-0.20/../../include/rtabmap-0.20/rtabmap/core/RtabmapExp.h:42:39: note: in definition of macro ‘RTABMAP_DEPRECATED’
   42 | #define RTABMAP_DEPRECATED(func, msg) func __attribute__ ((deprecated(msg)))
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1852:154: warning: ‘rtabmap::LaserScan::LaserScan(const rtabmap::LaserScan&, int, float, rtabmap::LaserScan::Format, const rtabmap::Transform&)’ is deprecated: Use version without "format" argument. [-Wdeprecated-declarations]
1852 |    scan = rtabmap::LaserScan(rtabmap::util3d::laserScanFromPointCloud(*pclScan), maxPoints, maxRange, rtabmap::LaserScan::kXYZINormal, scanLocalTransform);
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1862:153: warning: ‘rtabmap::LaserScan::LaserScan(const rtabmap::LaserScan&, int, float, rtabmap::LaserScan::Format, const rtabmap::Transform&)’ is deprecated: Use version without "format" argument. [-Wdeprecated-declarations]
1862 |    scan = rtabmap::LaserScan(rtabmap::util3d::laserScanFromPointCloud(*pclScan), maxPoints, maxRange, rtabmap::LaserScan::kXYZNormal, scanLocalTransform);
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1875:150: warning: ‘rtabmap::LaserScan::LaserScan(const rtabmap::LaserScan&, int, float, rtabmap::LaserScan::Format, const rtabmap::Transform&)’ is deprecated: Use version without "format" argument. [-Wdeprecated-declarations]
1875 |    scan = rtabmap::LaserScan(rtabmap::util3d::laserScanFromPointCloud(*pclScan), maxPoints, maxRange, rtabmap::LaserScan::kXYZRGB, scanLocalTransform);
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1885:148: warning: ‘rtabmap::LaserScan::LaserScan(const rtabmap::LaserScan&, int, float, rtabmap::LaserScan::Format, const rtabmap::Transform&)’ is deprecated: Use version without "format" argument. [-Wdeprecated-declarations]
1885 |    scan = rtabmap::LaserScan(rtabmap::util3d::laserScanFromPointCloud(*pclScan), maxPoints, maxRange, rtabmap::LaserScan::kXYZI, scanLocalTransform);
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/MsgConversion.cpp:1895:147: warning: ‘rtabmap::LaserScan::LaserScan(const rtabmap::LaserScan&, int, float, rtabmap::LaserScan::Format, const rtabmap::Transform&)’ is deprecated: Use version without "format" argument. [-Wdeprecated-declarations]
1895 |    scan = rtabmap::LaserScan(rtabmap::util3d::laserScanFromPointCloud(*pclScan), maxPoints, maxRange, rtabmap::LaserScan::kXYZ, scanLocalTransform);
c++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make[2]: *** [CMakeFiles/rtabmap_sync.dir/build.make:63: CMakeFiles/rtabmap_sync.dir/src/CommonDataSubscriber.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from /home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/MapGraphDisplay.cpp:172:
/opt/ros/foxy/include/pluginlib/class_list_macros.h:36:2: warning: #warning Including header <pluginlib/class_list_macros.h> is deprecated, include <pluginlib/class_list_macros.hpp> instead. [-Wcpp]
   36 | #warning Including header <pluginlib/class_list_macros.h> is deprecated, \
make[2]: *** [CMakeFiles/rtabmap_plugins.dir/build.make:63: CMakeFiles/rtabmap_plugins.dir/src/nodelets/rgbd_odometry.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:684: CMakeFiles/rtabmap_plugins.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/MapCloudDisplay.cpp: In member function ‘virtual void rtabmap_ros::MapCloudDisplay::update(float, float)’:
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/MapCloudDisplay.cpp:725:75: warning: ‘Ogre::Quaternion Ogre::TransformBaseReal::extractQuaternion() const’ is deprecated [-Wdeprecated-declarations]
  725 |       Ogre::Quaternion poseOrientation = frameTransform.extractQuaternion();
In file included from /opt/ros/foxy/opt/rviz_ogre_vendor/include/OGRE/OgreNode.h:38,
                 from /opt/ros/foxy/opt/rviz_ogre_vendor/include/OGRE/OgreSceneNode.h:38,
                 from /opt/ros/foxy/include/rviz_common/ros_topic_display.hpp:38,
                 from /opt/ros/foxy/include/rviz_common/message_filter_display.hpp:38,
                 from /home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/MapCloudDisplay.h:45,
                 from /home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/MapCloudDisplay.cpp:28:
/opt/ros/foxy/opt/rviz_ogre_vendor/include/OGRE/OgreMatrix4.h:198:36: note: declared here
  198 |         OGRE_DEPRECATED Quaternion extractQuaternion() const { return Quaternion(linear()); }
make[2]: *** [CMakeFiles/rtabmap_sync.dir/build.make:115: CMakeFiles/rtabmap_sync.dir/src/impl/CommonDataSubscriberRGBD.cpp.o] Error 1
In file included from /home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/InfoDisplay.cpp:125:
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/InfoDisplay.cpp: In member function ‘virtual void rtabmap_ros::InfoDisplay::update(float, float)’:
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/InfoDisplay.cpp:84:33: warning: unused parameter ‘wall_dt’ [-Wunused-parameter]
   84 | void InfoDisplay::update( float wall_dt, float ros_dt )
/home/eiforamr/ros2_ws/src/rtabmap_ros/src/rviz/InfoDisplay.cpp:84:48: warning: unused parameter ‘ros_dt’ [-Wunused-parameter]
make[1]: *** [CMakeFiles/Makefile2:951: CMakeFiles/rtabmap_sync.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
Failed   <<< rtabmap_ros [3min 29s, exited with code 2]
[Processing: rtabmap_ros]
Summary: 0 packages finished [3min 29s]
  1 package failed: rtabmap_ros
  1 package had stderr output: rtabmap_ros
The command '/bin/bash -xo pipefail -c source ${ROS_INSTALL_DIR}/setup.bash && colcon build             && rm -rf ${ROS2_WS}/build/* ${ROS2_WS}/src/* ${ROS2_WS}/log/*' returned a non-zero code: 2
Yihongyu
It works on my setup by adding "export MAKEFLAGS='-j2' " in the Dockerfile.
source ${ROS_INSTALL_DIR}/setup.bash && export MAKEFLAGS='-j2' && colcon build
Yihongyu
I met the same issue. Any fix now?
Thank you!
JesusE_Intel
Hi Yihongyu, Youngsik_Y_Intel,
Thank you for reporting, I was able to reproduce the issue on my side. I am reaching out for my peers for a fix or workaround. I will provide an update as soon as I hear back.
Jesus
Yihongyu
Nadia_J_Intel
Hi all,
You can also edit the Dockerfile on the amr_ubuntu2004_ros2_foxy_sdk_env folder on line 176
change the software-properties-common version to 0.99.9.* instead of 0.98.9.*.
After editing, you can then re-run the docker build.
JesusE_Intel
