Edge solutions - all 57 of them - listed here -
Example, if we go to Edge-AI-Box -
Click on 'Configure and Download', it goes to -
https://edgesoftware.intel.com/intel_video_aibox
The requested URL was rejected. Please consult with your administrator.
Your support ID is: 12567274115086019216
Hi SJX,
Is it possible for you to test from another network and/or computer? I tested with two different systems and accounts on different networks and I am unable to reproduce the issue. Could you share more information about your browser?
I tested on both Safari and Edge Browsers.
Jesus
Hi SJX,
Thank you for reporting! Are you still seeing this issue? If so, could you try from an incognito browser or clearing your cache? I just tested and I am unable to see the issue.
Jesus
Thank you for responding, Jesus.
I opened the link in a fresh new browser and I am now getting the login page and then able to go to the download.
Thank you. I am attaching the error I was getting on an already opened browser with plenty of tabs in the hope it will help somebody at Intel look into why such an error would occur.
Also the problem with incognito mode is that the download requires us to use Intel login which does not work in privacy mode.
Spoke too soon.
In the new browser, when I go to Intel® Edge Software Hub to reach the other implementations like 'Edge AI Box' or 'Smart AI Workload', I see a "Loading New Results' (see attached).
After it finishes in a couple of minutes, I see a "We're sorry, this service is currently unavailable. Please try again later (Error CVT01)" (see attached). There is some problem with cookies and such for sure.
Is the solution going to be to close and open browsers and/or clearing caches everytime that we want to access the 57 edge solutions?
In a new browser when I actually trying to download after accepting the license agreements, I am getting an error. Attached it.
Clearly, something is wrong with the entire edge sofware hub flow. Hope it is resolved soon.
@JesusE_Intel and @MaryT_Intel - Please mark this ticket as solved. Am not able to.
*unsolved
Hi SJX,
Jesus
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
