Hi
If we have to shut down any of the node in CSL network to insert movidius card or memory card, what steps we have to follow. Is there any recommended procedure.
I understand that, as containers will come up even there is power failure, but still if there any recommended procedure, kindly let us know
To disable the CSL node for some time and enable it back in the future, you can use the CSL Manager UI to do that. On the CSL manager UI, you can select the client nodes tab that will list all of the available nodes connected to the server. You can click on the maintenance on the button on the right column on the specific node. All the currently running containers of that node will be re-deployed to another available node. After done, you can just click on the maintenance off button to make the node available again.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
