Hello My Name is yoonju from south of korea.
I installed the Intel ECI Kernel by referring to the following site.
( When installing the kernel, it was installed with the ECI APT repository.)
https://eci.intel.com/docs/3.0/getstarted/verify_deployment.html#complete-and-verify-deployment
And it booted normally with Intel ECI kernel in Ubuntu 22.04.
Our main purpose here is to use the MCP2518FD Can FD I/F.
However, when I run Modprobe mcp251xfd in the kernel, it says there is no mcp251xfd driver module.
Isn't the corresponding module built in the built-in kernel? How should I solve this case?
Thank you for your reply.
Hello
This issue has been resolved.
The manager(Lay, Kuan Loon ) in charge delivered the guide by e-mail.
https://eci.intel.com/docs/3.0.1/development/kernel_building.html#step-3-build-linux-kernel
Thanks for your help.
Hello
Thanks for the update. If you need any additional information, please submit a new question as this thread will no longer be monitored.
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
