Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
408 Discussions
Provisioning error in castle lake client node while running in csl mode
Smrithi
I am trying to run pcb demo from the client node using orchestrator in csl mode. I did all the pre-requisites necessary for the  setup. But while trying to provision the castle lake client node using :-
sudo ./provision_eis.sh ../docker-compose.yml command I am getting the following error. I have also attached the SS of the error. Any help is appreciated.
ERROR: Service 'ia_csl_etcd_provision' failed to build: The command '/bin/sh -c curl -L https://github.com/coreos/etcd/releases/download/${ETCD_VERSION}/etcd-${ETCD_VERSION}-linux-amd64.tar.gz -o /EIS/etcd-${ETCD_VERSION}-linux-amd64.tar.gz && tar -xvf /EIS/etcd-${ETCD_VERSION}-linux-amd64.tar.gz -C /EIS/etcd --strip 1 && rm -f /EIS/etcd-${ETCD_VERSION}-linux-amd64.tar.gz' returned a non-zero code: 6
WengWai_C_Intel
Hi @Smrithi ,
From the screenshot you're providing, it show when the docker container build and trying to access github.com repo through internet but it failed to establish the connection . You will need to ensure the docker service in your system able to connect to internet so it will allow the open source component downloads to build the docker container during this provisioning step.
WengWai_C_Intel
Hi @Smrithi ,
