Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
426 Discussions
Temperature Issue in Intel RVC evaluation environment
Chinatsu_Miura
Greetings,
When booting with ECI_Debian, there is a phenomenon that the temperature of the PC rises compared to when booting with normal Debian.
The customer confirmed with the following command.
cat /sys/class/thermal/thermal_zone1/temp
CPU utilization comparison
・Normal Debian: about 1-2%
・Debian + ECI: about 0 to 1%
Temperature comparison
・Normal Debian: 37 degrees
・Debian + ECI: 75 degrees (rises to 84 degrees after startup, settles around 75 degrees due to high fan rotation)
The customer confirmed using the following Laptop PC.
https://www.pc-koubou.jp/products/detail.php?product_id=871229
We tested both ECI v3.0.2 and ECI V3.0 environments on the Intel NUC.
Neither of these have reproduced this phenomenon.
Intel NUC: SWNUC12WSHi7000 (CPU:i7-1260P)
This phenomenon is only seen in the customer's environment.
(I posted to Intel Premier Support earlier, but IPS replied that they recommended posting to the Edge Software Hub Communities.)
Miura/OEC
JesusE_Intel
Hi Chinatsu_Miura,
Thanks for reaching out. Do you know if the customer's system meets the system requirements as listed in https://eci.intel.com/docs/3.0.2/getstarted/requirements.html? You mentioned, this is only observed on the customer's system which is a laptop, do you have a laptop with similar specs to test?
Jesus
JesusE_Intel
Hi Chinatsu_Miura,
Jesus
JesusE_Intel
