Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
Bug when inverting embree::OrthonormalSpace3f ?
Clemens_E_1
I think I found a bug.
When calculating the inverse of an instance of embree::OrthonormalSpace3f via rcp(..) the resulting translation is wrong. I tracked down the problem to line 86 in common/math/affinespace.h:
  template<typename L> __forceinline AffineSpaceT<L>        rcp( const AffineSpaceT<L>& a ) { L il = rcp(a.l); return AffineSpaceT<L>(il,-il*a.p); }
Because of operator precedence, "-"  is evaluated before "*". It makes no difference for rotation matrices but makes problems for quaternions (negating them does not change orientation). So rather do
  template<typename L> __forceinline AffineSpaceT<L>        rcp( const AffineSpaceT<L>& a ) { L il = rcp(a.l); return AffineSpaceT<L>(il,-(il*a.p)); }
Can anybody confirm this?
Best,
clemens
SvenW_Intel
I think you are right, that is a bug. I just committed the fix.
