- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
In your displacement tutorial example code, what would happen if we could turn off the Catmull-Clark subdivision function? for example, if the rtcNewSubdivisionMesh() function had a parameter to turn off Catmull-Clark.
Does the user displacement function Embree calls with x number of points are the actual vertices of the new geometry done by the Catmull-Clark function? Basically, what are the points? just any random position on the mesh?
Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You probably need displacement on triangle meshes? This is not supported currently.
The displacement callback function is called for a number of points on the smooth catmull clark subdivision surfaces. The callback function can move these points. For quads in the original subdivision mesh, the points form a regular grid pattern.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
