Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
Crash when building BVH4 from secondary thread
stefankw
I'm seeing a crash in BVH4::rotate() when I'm using rtcCreateAccel from a secondary thread. This does not happen when I call it from the main thread or use the BVH2 instead. Is there something in the BVH4 memory management that depends on what thread it runs in?
stefankw
Nevermind, it turns out that pthreads on OS X default to a small stack size. Increasing the stack size for the thread fixed it.
SvenW_Intel
Hm, I have no idea what that could be. Does the issue also occur when you disable the tree rotations?
