Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
INTEL EN5322QI abnormal of X-ray inspection
HanjieDai
Hello Members,
We bought 3000pcs EN5322QI products(2000pcs datecode 2133 assembled in THAILAND and 1000pcs datecode 2133 assembled in MALAYSIA). During the X-ray inspection before use, we found that the products made in Thailand have problems with solder balls & abnormal of bonding wire  & less wires.please see the attachment of detailed information.
Please help to confirm whether the products have problems and can be used?
Thanks and Best regards
Sephult
Curious if I am seeing similar issue.
You stated Thailand and date code of 2133.
I do not have the package labelling and only have access to the lot and code on the part.
SGH02C / H133
I assume the 02 + 1 is 2021 and week 33?
The C = the change from gold to copper wire
I am going to be doing some xray inspection as well, one preliminary showed loose bonding wires similar to your THAILAND, and definitely looks to be a solder ball around the inductor as well. What failure modes were experienced?
With strange symptoms like processor JTAG degradation, or scan path failure, to kernel reboots post firmware loads. I assume I am experiencing potential current throttling causing unintended operation/functionality. Very interesting find
There is much appreciation and respect for sharing your findings.
Best Regards
-S
