Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1345 Discussions
Error: Can't launch Questa Intel FPGA Simulation software.
AK225
I'm unable to launch a simulation for a project and I keep getting the following error:
I'm using Quartus Prime Lite Edition 21.1 with a generated free license from Intel "Questa*-Intel® FPGA Starter Edition SW-QUESTA".
Steps taken so far to diagnose/fix:
1. Checked the license is the correct version and the NIC ID matches.
2. Checked the environment variable "LM_LICENSE_FILE" points to the correct file, and made sure the correct file is setup in the Quartus license setup options.
3. Ran "lmutil lmdiag", output shows "This is the correct node for this node-locked license"
4. Re-installed Quartus to make sure I only have the default starter edition installed.
5. Requested new license for the same product and replaced old one.
6. Made sure in EDA Tools, "Questa Intel FPGA" shows as the correct path "C:/intelFPGA_lite/21.1/questa_fse/win64" in my case.
I'm at a loss of how to move forward to resolve this issue. I require this tool to complete a university assignment and my lecturer and the university technicians could not resolve the issue.
Any support would be greatly appreciated.
AK225
The following is the Error log from Quartus:
Info: Start Nativelink Simulation process
Info: NativeLink has detected Verilog design -- Verilog simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode              :  RTL
Family                :  max10
Quartus root          :  c:/intelfpga_lite/21.1/quartus/bin64/
Quartus sim root      :  c:/intelfpga_lite/21.1/quartus/eda/sim_lib
Simulation Tool       :  questa intel fpga
Simulation Language   :  verilog
Simulation Mode       :  GUI
Sim Output File       :
Sim SDF file          :
Sim dir               :  simulation\modelsim
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script c:/intelfpga_lite/21.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Error: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode:  issued_nl_message
Nativelink TCL script failed with errorInfo:  Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
    while executing
"error "$emsg" "" "issued_nl_message""
    invoked from within
"if [ catch {exec $vsim_cmd -version} version_str] {
set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..."
    (procedure "launch_sim" line 88)
    invoked from within
"launch_sim launch_args_hash"
    ("eval" body line 1)
    invoked from within
"eval launch_sim launch_args_hash"
    invoked from within
"if [ info exists ::errorCode ] {
                set savedCode $::errorCode
                set savedInfo $::errorInfo
                error $result $..."
    invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
            set status 1
                set save..."
    (procedure "run_sim" line 74)
    invoked from within
"run_sim run_sim_args_hash"
    invoked from within
            error "$result" $savedInfo ..."
    (procedure "run_eda_simulation_tool" line 334)
    invoked from within
"run_eda_simulation_tool eda_opts_hash"
SyafieqS
Hi Andrew,
Did you able to resolve this or still need some help?
Anyway, have you tried on diff machine?
Is it possible to use latest std edition? (i think 22.1)
AK225
This issue is still unresolved, assistance would be appreciated.
Unfortunately this is the only machine i'm able to test this on, however other students have been able to get theirs working when following the same steps taken.
I've been instructed to use 21.1 as thats the version a lot of the lab sheets are based around, but if the differences are minimal it could be worth a try.
I'm able to provide a copy of the instructions followed for installation so you can see what steps were taken and where things might have gone wrong.
Many thanks,
Andrew.
SyafieqS
The step seem pretty correct.
Did you have any background app running when launching Quartus?
Also, sometime antivirus can be affecting the process.
Try to disable it temporary.
SyafieqS
May I know if there is any update?
AK225
Apologies for the delay in response.
The software is now working, I had given up on it until recently when I tried it again without changing anything since the original post and it works now, it wasn't anything to do with the antivirus etc.
Perhaps there was a large delay for the license to activate?
Andrew.
