Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
How can i see my directory?
MAsla5
初学者
1,734 次查看
The problem i am facing is, trying to access FPGA and want to see the relevant directory. FPGA is installed on the remote machine. I am in my pool and want to see OPENCL fpga directories to run my own kernel functions. Please could you guide how can i access?
FPGA : aria 10
Thanks!
0 项奖励
7 回复数
MEIYAN_L_Intel
1,539 次查看
May I know the information as below:
  1. OS used on remote machine
  2. Open SDK version
Also, may I know do you have setup for Arria 10GX FPGA Development board as link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an807.pdf
0 项奖励
MAsla5
初学者
1,539 次查看
Hi ,
Thanks for your response...
The remote machine OS is: Opensuse leap
version is : 15.0
Everything is installed on remote machine relevant to FPGA and OPENCL.
Now the problem is , when i run this command:  aoc device/hello_world.cl -o bin/hello_world.aocx -board=pac_a10
it says , command 'aoc' not found.
Do i missing something ?? I am just running this command from ssh on remote machine. .. Could you guide what i am missing regarding opencl? or relevant to this command?
Thanks!
0 项奖励
MEIYAN_L_Intel
1,539 次查看
I would llke to confirm with you, may I know what device you are using? The device use is Intel PAC with Arria 10GX FPGA or Arria 10GX FPGA? Since I saw in the command you are writing in pac_a10.
May I know which OpenCL SDK version you are using?
0 项奖励
MAsla5
初学者
1,539 次查看
I am not stuck there any more, but i have another question, I am not able to see report.html . This is what i am able to see but no report directory has been generated.
In image below , you can see no report directory is visible. I don't know why it's not generated?
I am invoking this command:
aoc -v device/vector_add.cl -report -o bin/vector_add.aocx=pac_a10
NOTE:: I am accessing it via ssh on my local PC.
Thanks!
0 项奖励
MEIYAN_L_Intel
1,539 次查看
I would like to confirm which OpenCL SDK version you are using?
0 项奖励
MAsla5
初学者
1,539 次查看
Here, you can find the version ...
Thank!
0 项奖励
MEIYAN_L_Intel
1,539 次查看
The OS: Opensuse leap 15.0 is not supported and validated in Intel PAC with Arria 10GX FPGA.
According to https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/acceleration-card-arria-10-gx/getting-started.html, the OS supported to Intel PAC with Arria 10GX is RHEL 7.4, CentOS 7.4, Ubuntu 16.04.
0 项奖励
回复
