Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
I had error when run Monitor Program
ISand6
When I run monitor program, I had this error:
insandjaja@pop-os:~/intelFPGA_lite/18.1/University_Program/Monitor_Program/bin$ ./intel-fpga-monitor-program
Java HotSpot(TM) 64-Bit Server VM warning: You have loaded library /home/insandjaja/flexdock/RubberBand.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
java.net.ConnectException: Connection refused
   at java.net.PlainSocketImpl.socketConnect(Native Method)
   at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
   at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
   at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
   at java.net.SocksSocketImpl.connect(Unknown Source)
   at java.net.Socket.connect(Unknown Source)
   at java.net.Socket.<init>(Unknown Source)
   at org.flexdock.docking.drag.outline.x11.Connection.<init>(Connection.java:35)
   at org.flexdock.docking.drag.outline.x11.Graphics.create(Graphics.java:49)
   at org.flexdock.docking.drag.outline.x11.Graphics.<clinit>(Graphics.java:34)
   at org.flexdock.docking.drag.outline.x11.X11RubberBand.<clinit>(X11RubberBand.java:14)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Unknown Source)
   at org.flexdock.util.Utilities.createInstance(Utilities.java:285)
   at org.flexdock.docking.drag.effects.EffectsManager.createRubberBand(EffectsManager.java:94)
   at org.flexdock.docking.drag.effects.EffectsManager.loadSystemRubberband(EffectsManager.java:137)
   at org.flexdock.docking.drag.effects.EffectsManager.prime(EffectsManager.java:43)
   at org.flexdock.docking.drag.effects.EffectsManager.<clinit>(EffectsManager.java:37)
   at org.flexdock.docking.drag.DragManager.prime(DragManager.java:42)
   at org.flexdock.docking.DockingManager.init(DockingManager.java:137)
   at org.flexdock.docking.DockingManager.<clinit>(DockingManager.java:127)
   at monitor.ui.UIManager.initDocking(UIManager.java:337)
   at monitor.ui.UIManager.init(UIManager.java:160)
   at monitor.globals.Globals.init(Globals.java:87)
   at monitor.Main.main(Main.java:36)
How to fix this?
