Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
Install Quartus Prime 18.1 on Ubuntu 18.04 LTS, but it fails to run due to missing libpng12 library. Isn't this something that should be caught before release?
TTetz1
Ubuntu 18.04 LTS is a supported OS for Quartus 18.1. Quartus won't run due to the missing libpng12 library (Ubuntu 18.04 has a newer libpng16 library). While it was relatively easy to find the libpng12 source and compile it, this seems like something that even a trivial QA test would catch. Just kind of wondering if it wasn't caught, or if it was caught but deemed not even worth noting in the release notes.
KennyTan_Altera
I will take a look into it
KennyTan_Altera
This seems to be known issue.. it will be documented soon. thanks
KBosm1
When will it be documented and where can we find that documentation?
KennyTan_Altera
Within this month, I will put the info here once it is published.
KBosm1
