Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
Why evaluation time expires for Quartus Lite Edition
JSone
If I compile using Quartus Lite Edition, I have a error as follows:
Error (210039): File
C:/Users/.../DE10_NANO_SoC_GHRD_time_limited.sof
contains one or more time-limited megafunctions that support the Intel FPGA
IP Evaluation Mode feature that will not work after the hardware evaluation
time expires. Refer to the Messages window for evaluation time details.
We are using Quartus Lite Edition .
We do not use any special IP.
We want to use USB 2.0.
I am appreciate, what above error of IP Evaluation Mode time expire.
Junji
CalvinJoaz_P_Intel
Hi Junji Sone, Good day. The evaluation time expires, you must reprogram the FPGA device before continuing hardware verification. To extend use of the IP core for production, purchase a full production license for the IP core. Refer link below on '1.1.4.1. Intel FPGA IP Evaluation Mode' - Page 8 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_intro_to_megafunctions.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Thank you.
JSone
Thank you for your support.
We bought license: at 2017/7/15
ORDER INFORMATION: Please save this email for your record.
Product                                Qty. License Activation Code #
IP-NIOS                        1 LAC# L52RS4FJCE6MYB
( Altera Order #: 0002054628 )
But, first we use Quartus Lite edition.
And We ask Customer Service Specialist of Intel, how to acitvate,
Then, he said Lite version is free and no license is required.
Now, we need to activate the IP license, I want to activate my license.
I am appreciate, if you inform me the method of activation of my bought license.
Junji Sone
JSone
Dear Officer.
Our problem is not programmer at Quartus.
We have a timelimted error at complation of my project using Quartus Lite edition 17.1.
I am appreciate, if you check it.
Junji Sone
sstrell
As mentioned, you have some IP in your design that requires licensing. The Lite edition is free to use, but if you create a design with IP, you either get time-limited .sof files, as mentioned, or you need to get licenses for the IP to remove the limitation.
CalvinJoaz_P_Intel
Hi Junji Sonne, Strell is correct! You can refer link below - Page 6 During Intel FPGA IP Evaluation Mode, the Compiler only generates a time-limited device programming file (<project name>_time_limited.sof) that expires at the time limit. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf Thank you.
JSone
Thank you for reply.
We are still hardware testing , because of my students is studying.
I am appreciate, if you inform me how to continue hardware testing mode.
Junji Sone
