Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Installing Quartus Lite 20.1 on Ubuntu 20.04
MTett1
I am trying to install Quartus Lite 20.1 on my ubuntu 20.04 but then I get this error which I have no idea on how to fix it.
Error: cannot find "/opt/intelFPGA_lite/20.1/modelsim_ase/bin/../linux_x86_64/vsim"
RichardTanSY_Altera
Hi.
You could check the below links for ways of fixing the error.
Let me know if it helps.
A Guide on Getting ModelSim to Work on Linux
ModelSim Linux installation
MTett1
@RichardTanSY_Altera
I have attached attached the vsim file below which is quite different from the previous versions of Modelsim. For example this `vco="linux_rh60" ` no longer exist in the current ModelSim version.
MTett1
mode=${MTI_VCO_MODE:-"32"}
arg0="$0"
cmd=`basename "$arg0"`
uname=`uname`
utype=`uname -r`
umach=`uname -m`
case $uname in
AIX)
islink=-L
CYGWIN_NT* | MSYS_NT*)
islink=-h
Win*)
uname=CYGWIN_NT
islink=-h
islink=-h
esac
while [ $islink "$arg0" ] ; do
x=`/bin/ls -ld "$arg0"`
x=`expr "$x" : '.* \(.*\)'`
case "$x" in
/*) arg0="$x" ;;
*) arg0="`dirname ""$arg0""`/$x" ;;
esac
done
dir=`dirname "$arg0"`
#added
export LD_LIBRARY_PATH=${dir}/lib32
vco=${uname}${utype}
case $vco in
Linux*)
# On Linux, default to 32 bit unless MTI_VCO_MODE is set
# except for Visualizer where we invoke 64-bit version by default
if [ "$mode" = "" ] ; then
if ( [ "$cmd" = "visualizer" -o "$cmd" = "vis" ]) \
&& ( [ -x "$dir/linux_x86_64/visualizer" ] ) ; then
mode="64";
elif ( [ -x "$dir/linux/vsim" -o -x "$dir/linuxpe/vsim" ] ) \
&& ( [ "$umach" != "aarch64" ] ); then
mode="32";
fi
fi
# If IA-64 or X86-64 architecture and machine-specific vsim is not
# installed but linux vsim is available, use linux platform.
# Otherwise use machine-specific platform.
if [ "$mode" != "32" ] \
&& ( [ "$umach" = "ia64" ] \
|| [ "$umach" = "x86_64" ] \
|| [ "$umach" = "aarch64" ] ) \
&& ( [ "$mode" = "64" ] \
|| [ -x "$dir/linux_$umach/vsim" ] \
|| [ ! -x "$dir/linux/vsim" ] ) ; then
vco="linux_$umach"
else
vco="linux"
if [ ! -x "$dir/$vco/vsim" -a -x "$dir/linuxpe/vsim" ]; then
vco="linuxpe"
fi
fi
if [ -x "$dir/win32/vsim" ]; then
vco="win32"
elif [ -x "$dir/win32pe/vsim" ]; then
vco="win32pe"
fi
if [ "$mode" = "" ] ||
[ "$mode" = "64" ] ; then
sysostype="`systeminfo 2>&1 | grep -i 'System Type' | cut -f1 -d- | sed s@x@X@ | cut -f2 -dX`"
if [ "$sysostype" == "64" ] ; then
vco="win64"
fi
fi
vco="unknown"
esac
doatenv=0
case $cmd in
qhdir)
cmd=vdir
qhmap)
cmd=vmap
qvlcom)
cmd=vlog
qhlib)
cmd=vlib
qhsim)
cmd=vsim
qhdel)
cmd=vdel
qhmake)
cmd=vmake
qvhcom)
cmd=vcom
qhgencomp)
cmd=vgencomp
vco)
echo $vco
exit
hdloffice)
doatenv=1
hdlstudio)
doatenv=1
esac
# verify that we can find the command to execute.
if [ -x "$dir/$vco/$cmd" ] ; then
arg0="$dir/$vco/$cmd"
else
# if bin nolonger has symbolic links in it then
# we need to look up and over
f2="$dir/$vco/$cmd"
if [ -x "$f2" ] ; then
arg0="$f2"
elif [ -x "$dir/${vco}pe/$cmd" ] ; then
arg0="$dir/${vco}pe/$cmd"
elif [ -x "$dir/${vco}le/$cmd" ] ; then
arg0="$dir/${vco}le/$cmd"
else
# Last ditch effort. Use original arg0 and try it!
d2=`dirname "$0"`
f2="$d2/$vco/$cmd"
if [ -x $f2 ] ; then
arg0=$f2
else
echo "Error: cannot find \"$dir/$vco/$cmd\""
exit 1
fi
fi
fi
if [ $doatenv ]; then
if [ -x "$dir/$vco/athdlenv" ] ; then
#. $dir/$vco/athdlenv
if [ -z "$LD_LIBRARY_PATH" ]; then
export LD_LIBRARY_PATH="$dir/$vco"
else
export LD_LIBRARY_PATH="$dir/$vco:$LD_LIBRARY_PATH"
fi
#echo LD_LIBRARY_PATH=$LD_LIBRARY_PATH
fi
fi
if [ -z "$*" ] ; then
exec "$arg0"
else
exec "$arg0" "$@"
RichardTanSY_Altera
I think it is best that you try to re-install the latest Quartus version and the corresponding Modelsim version. Check that the hardware and software requirement are met before installing.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
RichardTanSY_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
hectorca
Hi @MTett1,
I was able to workaround this issue exporting the following environmental variable:
export MTI_VCO_MODE=32
The problem seems to be that Modelsim detects that Ubuntu is a x64 OS, but the installer Modelsim Intel Starter Edition only can run in 32 bits mode.
Exporting that variable to your environment will make Modelsim to be executed in 32 bits regarding the OS architecture.
