Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Quartus Prime Floating License
Sahil_Honeywell
I am installing Quartus Prime Floating license.
I have the .dat file. But I dont know how to set the path to the alterad vendor daemon executable. I dont even know what what and were the daemon files are.
My understanding is that I need to install the license on my machine and then I can give access to my team members(as I bought 3 seats). Is there anything else I need in terms of hardware, like an external server to get license working
I have been struggling a lot with this. Would appreciate help on this.
AR_A_Intel
Hello
Welcome to Intel forum. But before setting up license, would you kindly help check, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
Make sure the port used by license server or vendor daemon is not blocked. The port number is required for Windows systems and should be outside of the 27000-28000 range and be unique on the machine. The following example shows how to specify port numbers in a floating license file. example, specify ports 1800, 1801, and 1802.
SERVER myServer 0123456789ab 1800
VENDOR alterad ./alterad port=1801
VENDOR mgcld ./mgcld port=1802
Please stop and restart the server. You need to allow the firewall access to the port number from both server and client machine.
You can also refer to link below for more detailed instructions for Setting up a floating network license server (page 37 of 59):
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/manual/quartus_install.pdf
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgG
You can also refer to this following YouTube on Setting up and debugging Quartus floating licenses.
https://www.youtube.com/watch?v=llLaWatUbe8
Let me know if this information is helpful.
Sahil_Honeywell
Please tell me where is the license server or vendor daemon. I am not using any external server. I have simply installed license in my laptop machine. Do i need an external server?
Also,  https://www.youtube.com/watch?v=Ob9ei5lMgG   This link in unavailable
AR_A_Intel
Hi
A Floating license is a floating network (multi-user) license for users running the Intel Quartus Prime software on multiple computers connected on a network. Yes, a license server is needed to issue licenses to computers on demand.
You can refer here for more: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
The following is YouTube for license setup.
https://www.youtube.com/watch?v=Ob9ei5lMgGE
AR_A_Intel
We do not receive any response from you to the previous reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
