Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Intel FPGA SDK for OpenCL still looking for license files.
AKell
When running Quartus through the OpenCL design flow, it works fine when $LM_LICENSE_FILE is unset. I think this is the expected behavior, as it says
  • "The Intel® Quartus® Prime Software does not require a license purchase when used as part of the Intel® FPGA SDK for OpenCL™
here
https://www.intel.com/content/www/us/en/software/programmable/sdk-for-opencl/overview.html
However, when $LM_LICENSE_FILE points to a license server where older licenses are present or an older version of the license daemon is running, the flow fails, in our case with
Error (119013): Current license file does not support the 1SG280LN2F43E2VG device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
I'm not sure if it will actually block a valid license when it finds it, but I think the behavior is unfortunate for a tool that is supposed to run without license.
KhaiChein_Y_Intel
May I know the version of the software and license daemon you are using?
KhaiChein_Y_Intel
Any updates?
TKent1
$ aoc -version
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 19.1.0 Build 240 Pro Edition
Copyright (C) 2019 Intel Corporation
We recently updated to this license server and daemon, but the problem persists:
$ ./lmutil lmstat -a -c $LM_LICENSE_FILE | grep -E 'INTEL|MASTER'
license server UP (MASTER) v11.16.2
   INTEL: UP v11.16.2
Before the license setup was:
 license server UP (MASTER) v11.15.1
INTEL: UP v11.15.0
KhaiChein_Y_Intel
KhaiChein_Y_Intel
Hi, May I know if you have any updates? Thanks.
